How do I moved apps to SD Card????
Here is my problem: A couple of apps were being updated (automatically) and failed to finish updating due to insufficient memory. I checked my storage memory and it shows that "miscellaneous files" are taking up too much of my Device Memory. My SD Card memory has about 10.01GB Available Space / 14.62GB Total Space. After seeing this, I tried transferring my photos in my gallery into the sd card but it says "Unable to move. File already exists." I checked the 'camera' album that saved to sd card but there isn't a copy or anything of the pictures I tried to move. Another problem I'm having is that when I tried to delete some pictures saved in the camera album under the sd card, it'll delete it and then pops back up in the album. Why? I've tried changing the setting in the camera to save to sd card and it'll have the sd icon in the top right hand side but when I take a picture (with & with out flash) it says "cannot write file in sd card. Default storage is changed to phone storage." How do I free up tons of space on my device memory? Can I delete apps or widgets that came on the phone when I purchased it, like flipbox, those tons of clocks (besides the one im using), etc,.?
I would suggest getting an app called Clean Master from Play. It will clean up any cache you have, wipe residual files and such. Before doing that, I would connect your phone to your PC, and transfer any files you have that don't need to be there (pictures, videos, etc) until this can be fixed. Clear out your internal storage as much as you can. When done, attempt the updates again, and install the cleaner app and run it. Also probably wouldn't be a bad idea to clear out your SD card as well.
As for deleting apps/widgets that came pre-installed on your phone, you can disable them through the Application Manager, but as for deleting them, you can't until you are rooted and acquire appropriate apps like Titanium.
ameliadinkins
