How do I remove demo mode?
  • Start date Start date
A
AC Question
remove demo mode????
my son was playing on his tablet when the word DEMO in big red letters popped onto his screen he doesnt know how or why how do i fix this??
I have p9 huawi and I had the same problem and I did like you said befor,(
1- Keep pressing power button to restart mobile
2-. As soon as vibrate press volume up button along with power button.
3- When huawei logo apear release power button and do not leave volume up button.
4- EMUI interface will be displayed
5- Tap factory reset
6- When complete tap Wipe cache partician
7- Restart Mobile )
and I lost all the photos, there is any way to restore them? :'(
How do i exit Retail mode from my Micheal kors access Bradshaw watch? I have tried all I've the above and I have tried other suggestions for 4 hours now.
Please help
Thanks in advance
So after hours of working on my android tablet. I did a hard rest. when it turned back on it hadnt worked. Until i held in power button again and it gave me the option to reboot. after i rebooted it finally worked so if you did a hard reset and it didnt work.. try this.. hope it helps.. thanks:)
This is how you take your android S8 out of demo mode
Open Settings
Open About Phone
Open Software Information
Locate Build Number
Rapidly tap on Build Number 7 times or until you see the pop up.
Pop up will alert you that Developer Mode is now available.
Go back to Settings
Scroll to the bottom of the list
Open Developer Options
Open Demo Mode
Clear the two check boxes
Close settings
Done
Hello I'm looking any solution i have LG G7 ThinQ Demo unit doing this after flash with another firmware 👇
Before i wasn't flash this device it was
Android version
8.0.0
Android security patch level
1 September 2018
Kernel version
4.9.65
Build Number
OPR1.170623.032 test-keys
Software version
V10v-COM-XX
But after flash this device with another fimwere now
Wi-Fi not working
And when you swich it On after some minutes overheating and goes Off then powering again then goes Off again
Hello I'm looking any solution i have LG G7 ThinQ Demo unit doing this after flash with another firmware ������
Android version
8.0.0
1 September 2018
Kernel version
4.9.65
Build Number
Software version
V10v-COM-XX
Wi-Fi not working
Welcome to Android Central! This is a pretty old thread, so you may want to create a new thread in the G7 forum: https://forums.androidcentral.com/lg-g7-thinq/
Ashok Dharshan
