How do I stream from my Note 5 to smart tv without wifi?
  • Start date Start date
A
AC Question
How to stream from my Note 5 to smart tv without wifi
I don't have wifi at home.
I have a Galaxy Note 5 with T Mobile, with unlimited data.
I have a new Samsung Smart TV (Samsung J5200 Series).
I'd like to stream movies from my Note 5 to my TV without wifi.
I tried the Samsung Micro USB to HDMI Adapter (MHL), but it didn't work.
Is there any other way?
Many thanks!!
Re: How to stream from my Note 5 to smart tv without wifi
I believe micro usb to hdmi is the only other option but as you stated that doesnt work so you might just be out of luck
Posted via my Samsung galaxy S5
Not sure if it requires wifi or not but on the Samsung TV change the source to Screen Mirror, then on the phone swipe down and if you don't see Screen Mirroring icon then click on edit so you see more icons (don't click on the gear icon). Press on Screen Mirroring and it should locate your TV and then select it... this is if it does not require wifi. If this does require wifi then the 4th post in this thread said they used the Amazon Fire Stick as it doesn't require wifi to mirror http://forums.androidcentral.com/sa...get-galaxy-note-5-mhl-work-what-can-i-do.html .
Vresbudsbenz
