How do I turn off the accessibility screenreader??!
Thank you so much for this info. Apparently I wasn't the only one ready to throw my tablet out the window over this irritating feature.
If u have turned u r acessbility on dnt worry, first select settings and double tap it and with both thumbs scroll it down to accessibility in u r setttings turn off talkback in settings u will b back to u r phone thnx for reading
This just happened to me after I downloaded dynamic notifications. You have to goto settings from the home screen and using two fingers you can scroll down to "accessibility" double tap it to open it, scroll down to "talk back" double tap it and double tap the toggle off. That should be it good luck, took me over and hour to figure out and was getting severely pissed
Sent from my SCH-I535 using AC Forums mobile app
U r a life saver man
Thanks a ton. I was going crazy with the talk back which I had activated by mistake. Your solution worked like magic. As someone said earlier, I would not have thought of the 2-fingers solution in several years!!
Thanks once again...
I just wanted to say thank you for the information, it was very helpful. It took me less than an hour because I had Google who led me to you, thank you and have a good one!
Never again. I was ready to toss my watch when I read your post. Now it works but when you have long nails it takes a little longer lol. Thank you for your advice it works took me sometime but it did. Thank you so much.
Your a genius that is an awful thing to try.
Annuji202
