How do I uninstall Battery Doctor - its lock screen has locked me out?
bodwyn
4
I installed Battery Doctor.
After a couple of days, I conceded to let it manage the lock screen PIN so I didn't hve to swipe twice to enter it.
BDr then sid I'm entering the wrong PIN.
I reset the main phone PIN using google device manager, so now I get the normal lock screen, I enter the PIN, then the BDr lock screen appears.
I can briefly see the home screen between actions of the BDr lock screen (it lets you see battery, weather, you can open a calcultor), but I haven't found a way to sneak past BDr lock screen, but that may indicate to someone the nature of its lock screen.
I downloaded ADB.exe by xda developers to try to remove BDr but can't figure out how, if you have any tips.
I want to avoid a factory reset as I don't want to lose data, photos on the phone (Archos 55 platinum).
Re: How do I uninstall Battery Doctor - its lock screen has locked me out
Connect your phone with PC. Open a command prompt in the window where your ADB.exe is and type this commands one by one:
Code:
adb.exe shell
cd \data\app\
rm com.ijinshan.kbatterydoctor.apk
I wrote this assuming the app name in the phone is com.ijinshan.kbatterydoctor. If you ran in to any problems just ask. :)
