How do I use the power key and the volume key to get to the reset option on my Android phone?
  • Start date Start date
A
AC Question
how do i use the power key and the volume key to get to the reset option on my android phone
I need to know how to use the power key and the volume key up or down or middle to factory reset my Android phone because it won't go past the tracphone menu after it was turned off and on
Re: how do i use the power key and the volume key to get to the reset option on my android phone
When the decvice is completly powered off, hold the volume up, power and home button all at the same time. Then use the volume keys to move your cursor and the power button to select.
marik999
