- Feb 6, 2017
- 99,101
- 15,812
- 113
Yes Sam MobileDo you mean SamMobile?
I tried different cables with same outcome.. and they worked with galaxy a20e...
Try different ports
Did not worked...Yes Sam Mobile
Try different ports
Can you show a screenshot in download mode with phone connected in Odin?Did not worked...
I believe it´s not a cable drivers issue because everything goes ok with a20e.
I start to accept there is nothing to do for this phone!
@mustang7757, thanks for you time!!Can you show a screenshot in download mode with phone connected in Odin?
Ok so Sam Mobile website see if you find your firmware and download it@mustang7757, thanks for you time!!
Ok!! Odin recognized device!!!
But Frija in AutoMode does not, so i´m not sure what rom i use to flash!!
I get a error: Re-Partition operation failed.Ok so Sam Mobile website see if you find your firmware and download it
I found another rom. Flashed ok but after reboot stays on Samsung logo... The same problem.I get a error: Re-Partition operation failed.
Wrong rom? I used: https://samfw.com/firmware/SM-A505FN/MEO/A505FNXXU9CWB4
CSC in Odin which file you used Home CSC or regular?I found another rom. Flashed ok but after reboot stays on Samsung logo... The same problem.
Could be a hardware problem?
I use CSC that came with rom... What it's the other option?CSC in Odin which file you used Home CSC or regular?
Usually the firmware comes with 2 CSCI use CSC that came with rom... What it's the other option?
If that's the case then something with hardware needs repairs and if it's worth it send in to SamsungAt this point i flash 5 different roms and the outcome was always the same:
After flash ended and reboot the phone stays on samsung log until i disconnect from Pc. After the disconnection it turns off and the on/off button do not work and the only way of have some life signal from device it´s connect to pc and press volume buttons (download mode access) or connect it to charger (samsung log forever).
Exactly same behaviour from beginning...
Thanks for the time and help. It's probably a hardware problem on an old mobile phone and where no investments are worth.If that's the case then something with hardware needs repairs and if it's worth it send in to Samsung
You're welcome , anytimeThanks for the time and help. It's probably a hardware problem on an old mobile phone and where no investments are worth.
It was worth a try and gave me a chance to know some basic samsung tools and functions. I'll use them now to try a custom rom on a galaxy a20e in good condition and that won me in a first round thanks to the "validating footer error"... but I'll try again
Thanks again!!
