How do you connect a USB device endoscope camera and make it work?
  • Start date Start date
A
Android Central Question
Others have said the camera works with the full size USB connector not the micro size. How do you connect a Full size USB connector to the Galaxy S8+?
You'll need a USB on-the-go (USB OTG) cable. Those are easy to come by, but make sure to get a USB C to USB A female cable. The S8 doesn't have a micro-USB port. Something like this should work.
https://www.amazon.com/gp/aw/d/B06X...ag=hawk-future-20&ascsubtag=UUacUvbUpU6113471
More importantly, you'll likely need an app that can talk with the camera. That is something I'm not sure exists for universal applications. I did a quick search and did see some endoscopes for Android, but they all had the micro-usb connection on the cable. Whether or not one of their apps would work with your device is beyond my knowledge.
kiki2025
