How does Storage + Micro SD work on the S7 Edge?
sLithery
75
Assuming I add a 64GB Micro SD to the S7 Edge does the phone have two storage systems or one?
1st option: 32GB + Micro SD storage(64GB)
2nd optiom: 96GB
I also use Spotify can I add my offline Playlists to the Micro SD card?
It has one, your first option. How spotify will work is not yet know AFAIK.
Two storage systems, 32gb phone and 64gb on the card.
Samsung haven't included the marshmallow feature "adoptable storage" which would format the card to act like internal storage at the sacrifice of being able to use the card in anything else until you reformat.
Personally this doesn't bother me at all as I'll store photos, music and videos on my 64gb card and the amount of apps/games I usually use will easily fit 32gb.
But I understand why others who play more games would find this annoying.
I can't answer for Spotify, but I know deezer (Spotify rival) allows you to save to external storage, you would hope Spotify would too.
Spotify does let you store on the sd card. This includes offline playlists
I've already read the FAQ I just heard from some people that it doesn't work.
Also thanks to everyone who've helped me. 😊
