How is the WiFi connection and speed on Droid Turbo
Deron Baker
314
32
For those of you who are using a Turbo, how is the WiFi radio? I had on and off problems with the WiFi on a previous Droid Razr Maxx HD phone. It kept dropping connection to the network, both at home and work.
Has anyone had any problems staying connected to WiFi? Is WiFi signal strength good? Speeds?
Any input is really appreciated.
Sent from my XT1080 using Tapatalk
It was great all day until I was streaming Thursday Night Football last night. Occasionally the signal drops significantly and video stuttered when I put my hands over the top edge of the phone (basically when holding phone with two hands in landscape mode). I'm gonna keep an eye on this for a few days and let you know if it continues.
PS. Who Dat! Geaux Saints!
Sent Turbo fast from my 64GB Droid Turbo
Sounds like they didn't think about radio placement for landscape view :(.
Its not that it doesn't work at all. The wifi signal strength just drops off and then comes back.
I read your post last night about this so i fired up the NFL app and streamed the game and no matter what i tried i could get it to lag or stutter at all.
No problem for me at all with wifi. Which version did everyone get? I got the red MGF, i wonder if the material has something to do with it
Posted from my Droid Turbo, Kelly and Ozone
Thank you for testing NFL. Maybe it is the ballistic nylon I have, or my wifi network, or just my magnetic personality? Lol
Either way, I'll try it again this Sunday while watching Red zone on the Turbo.
How is the range on the Wifi. I am somewhat far from the wifi router and I have an iPhone from work and it is not perfect put it stays connected with decent speed. My personal phone, droid maxx always dips in and out of connection or quality of the connection. I was wondering that is that the same case with the Turbo or is the wifi antenna strong and can get good wifi signals from the farther end of the range of the wifi router. I doing want to use my data plan all the time if I can get a wifi signal. It sounds like so far it is not very strong in the Wifi department.
I had problems with streaming video one time with NFL mobile. The rest of the times have been fine including Band of Brothers in HD over Amazon Instant Video last night. No problem then. I'm thinking it might be the NFL Mobile app causing lag.
As far as range, it is pretty darn good. I have a network extender and I get way better connection than I did with with my Droid Razr M. Usually full or 4 bars all over the house.
Actually, I restored 400MB of pics from VZW cloud over WiFi this morning (while streaming Pandora and downloading apps from Play Store!) and it was really fast!
Sent Turbo-fast from my bulletproof 64GB Droid Turbo
Actually, I restored 400GB of pics from VZW cloud over WiFi this morning (while streaming Pandora and downloading apps from Play Store!) and it was really fast!
400GB of pictures over WiFi to a 64GB phone. Talk about skill using a shoe horn
My WiFi signal seems to be pretty consistently weak. I had full or almost full signal at my house with my galaxy s3, but have 1 bar with my turbo. It occasionally bumps up to 2 bars or down to 0...
The WiFi reports are puzzling. My signal is at least as strong as my Maxx and the speeds are about double, approaching that of hardwired computers. Since installing an Asus AC68U router some time back I've had exceptional range on the 2.4G band and will reach beyond 200 yards down the street in one direction from my house. I ran a speed test there with the Turbo and it equalled my Maxx from within my living room. I'm elated with WiFi performance & phone signal is unchanged (and good) from the Maxx.
First, make sure to go to WiFi menu, then click the menu button and to to Advance settings. Make sure that option to "Avoid poor connections" is unchecked. Turn that stupid setting off. Nothing but trouble on previous phones when I had that enabled.
Here are some Speed test dot net app readings I got with my Droid Turbo and iPad Air (for comparison). The top reading is 4G, but the other three readings are WiFi. I stood in different places for each respective reading, but did it in the same spots for each device. One reading was in the farthest part of the garage while the router is upstairs on the other side of the house. The bottom most reading is standing 3 feet from the router. My Droid Turbo actually has decent WiFi speeds and connection strength.
First pic is Droid Turbo readings, second pic is iPad Air readings. I live in Sanford, FL. I am using a cable modem with advertised speeds up to 90 megabits per second. Although the Droid Turbo did well, iPad Air dominated.
My Droid Turbo seems equal or better than my Droid Maxx for WiFi signal strength.
Is the Wi-Fi Signal consistently weak with all the APs or you are observing the issue only with the AP in your house? Also is your phone in a folio? Can you please provide the AP name, AP configuration and firmware of the AP you are using in your house?
alanmagdaong
