how long does battery last on airplane mode?
pnico
242
Hi,
im traveling to Italy and Greece and purchased 2 battery packs for use on the flight overseas.
Im thinking the razor battery on airplane mode should last a while since it isnt constantly hopping towers, right?
Any idea how long this would last?
It is a 10 hour flight and im thinking with the stock battery and 2 battery packs, I should be ok to use it for a large portion of the flight?
Thanks
10 hours of constant use should get u through the flight. I would do a test before u go.
Sent from my DROID RAZR using Tapatalk 2
what airlines are you goin on? Quite a few of the planes are being fitted (retrofitted) with USB connectors now, you might want to check with the airlines...
Reactions: bradenfontaine
thanks for the info. Im flying us air and last year they did not have anything like that. They may now, I dont know.
If not, they probably have power outlets, in which case you can just get a power inverter and just keep it charged. I would imagine it would last 10 hours for the flight though.
On airplane mode and depending if your playing a lot of games should be no problem going the flight especially since you say your taking extra battery packs. If your not going to be playing games just turn the phone off
Nehasingh12
