How long does it take your Extended Battery to charge?
smooth4lyfe
Trusted Member
Sep 16, 2012
5,534
Which extended battery do you have, and how long does it take to charge?
I recently got the GorillaGadgets 4500mah Battery and it takes a really long time to charge to 100%...I know its a bigger battery so is it supposed to take much longer?
Should I Calibrate my battery?
Also everyone answer the first question loll
I think the length of how long a battery charges has to do with the current or amount of voltage (mah) the battery uses. So if there is a battery with lets say 4 voltage and one with 2 (random numbers), but they are the same size (mah) then the 4 voltage would charge faster. The charger you use also would matter.
sukarisw02
