How long should I charge my Note Edge for the first charge?
  • Start date Start date
A
AC Question
first time charging?
hi i got me the new galaxy note edge and they said i must charge it for 8 hours for the first time!! when i open my box it was sealed i put in the battery and put it on charge and the battery was already charged 63% and was fully charged in a hour time!! must i still charged it for 8 Hours????
Re: first time charging?
Welcome to Android Central! Not really. They say that more for liability reasons. You really just have to charge it until it hits 100%, and maybe for another 30 minutes afterwards. Then use the phone normally.
When I get a new device, I run the current battery down to 0%. Charge it fully then run it all the way down again. Charge it up and you good to go.
Posted Via Galaxy Note Edge. Yea, the phone is perfect...
I have read on a lot of tech sites that running these batteries to zero is actually bad for the battery. I know they don't have memory anymore, so "training" the battery is no longer needed. I plug mine in whenever I am going to be in one spot for about an hour. Not a problem with the battery, if I want I can go all day without a charge, but I don't GIMP my phone. Live wallpapers, full brightened, and everything on that I might possibly need. ;)
Sent from my Samsung Galaxy Note Edge via AT&T using Tapatalk
There is some theory that you should really charge the battery when it gets to 40%. ...but with a removable battery I'd not worry too much.
📐♻from the Note Edge🔍
I have read on a lot of tech sites that ruining these me batteries to zero is actually bad for the battery. I know they don't have memory anymore, so "training" the battery is no longer needed. I plug mine in whenever I am going to be in one spot for about an hour. Not a problem with the battery, if I want I can go all day without a charge, but I don't GIMP my phone. Live wallpapers, full brightened, and everything on that I might possibly need. ;)
Never had a problem. I got my Edge (Sprint) the day it was released. I put it on the charger an hour before I leave for work to get a full charge. Moderate to heavy use while at work (9 hours) leaves me at approximately 32% by the time I get home. Phone doesn't go back on the charger till the next day before I go back to work. My experience? I'm good. 😃
hi i got my new note 5 and my brother told me u should charge it for 3 to 4 hours before start to use it ..but when first time i took out it from the box and plug in the charger it was already charged 23percent ...but i kept my mobile on charge and it complete 100 percent charge almost less then hour....so my queation is should i use it or still keep it on charge for next some hour although it is 100 percent charged
aloha17
