How often do you charge your Gear?
My Gear lasts about 4 hours on a charge. I'm using it only for selected things. Still using my Pebble for everyday.
After the last update I lose about 10% - 12% per 10 hour work day, set on vibrate max brightness on 5. I get 3 to 5 notifications per hour.
I charge it about once or twice a week.
Before the last update I would lose about 30% per 10 hour work day.
I power it on at about 8 a.m every work day.
I charge every night just because. Still, in a day I never go below 45 percent. Don't understand people who do everything they can to trash something if they can't get more than a whole day on a charge.. Just plug it in when you sleep.. If your getting 4 hours with little use on one charge then you have a defective watch.
THE BEAST,,NOTE 3. SIZE IS EVERYTHING!!!
I charge mine nightly - some days when I use it extra hard (ESPN notifications, alot of Gmail, etc) I will put it on charger for about 30+ minutes in the middle of the day.
It seems to me the charging is quite fast. For instance if the battery is around 20% and its on the charger at least 30 minutes the battery will already be at > 80%.
I only wish I could get an extra charging cradle for the GG at a reasonable price. God forbid I lose the only one I have in carrying around or taking it to my girl friends house, etc.
If the cradle gets lost my GG is literally a paper weight.
Samsung has had it on backorder for several weeks and I can't find any locally. It would be nice if Best Buy had them in stock.
Ebay and Amazon have them but for twice the listed price. :-\
5-6 hour light day uses maybe 20-25%. If your turn it off when you aren't using it at home it can last a long time.
Isn't it like with smartphones? Where it's best to keep them as juiced up as possible, instead of letting them run dry or almost dry? I've once heard that Li-On batteries are better off in the long run being charged every day, rather than just dropping down to 10%.
Should be the same logic with smartwatches, if in fact it is true about the battery longevity and this charging method.
amateur_user
