[HOW-TO] ╰╮╰╮REVOLUTIONARY╰╮╰╮ Get S-OFF, Recovery and Perm-Root!
Re: [HOW-TO] ╰╮╰╮REVOLUTIONARY╰╮╰╮ Get S-OFF, Recovery and Perm-R
Check to see if you have the drivers installed and HTC Sync uninstalled. Also... check to see if adb can see your device... Sounds like an ADB issue with it not seeing your device...
ADB found my device. And I never installed HTC Sync, even checked to make sure and no, it isn't installed. It only says "Waiting for device..." and nothing else
You need to install HTC Sync and then Uninstall it. It installs all the needed drivers.
Reactions: stashu11
Ok, installed HTC Sync, then Uninstalled. Still get the Waiting for device message when I run revolutionary
are you selected to CHARGE ONLY mode on your USB for the phone... check
Reactions: ChrisAC84
woot its worked after fast boot off
Yeah, it is set to Charge Only. USB Debugging is on, Fastboot is off
EDIT: Unplugged my phone, then plugged it back in, and it worked. Finished the S-Off process, now moving onto the recovery/rooting process. Thanks for the help :)
I wasn't able to get the clockwork mod installed automatically. How do I do this manually?
Reactions: cosmos0001
Check the 2nd post.. I have detailed instructions on how to do so...
I have done the steps to get S-OFF (shows successful on boot) and made a nandroid backup, but I'm getting an error on flashing the "E:Error in /tmp/sideload/package.zip" error and it's not giving me superuser access...
What's wrong and what do I do? :-\
EDIT! I put the "su-2.3.6.3-efgh-signed.zip" file in the /tmp/ folder and POOF it worked! I just tried Titanium backup and it allowed SU access!
GUY GUYS ROCK SO HARD!! =)
Run into another issue. I can't get Titanium Backup to work. It keeps giving me an error, and tells me I'm not rooted. I have downloaded/installed BusyBox, uninstalled TB, rebooted, then renistalled, reflashed the su Zip, and nothing. ROM Manager works for me (reboots into recovery, after I grant it root access) so I know my phone is rooted. Any ideas? And I also tried a method posted on XDA about removing some data/bin files, but they weren't present on my phone
Sorry no clue on that one. I dont use Titanium personally. Good luck tho! :)
Install BusyBox from the Market
Titanium Backup can be picky about its Busybox version. Did you install Busybox separately or did you let Titanium Backup install it for you?
Sent from my Nexus S
Reactions: jondevere
I can't make phone calls after rooting... Can anyone confirm calls working?
I can make calls
Several people are having to call Sprint, just play dumb, they will reset it on their end.
I would love to know how many phone calls Sprint got tonight.
did anyone get overclock work after perm root
i have same problems like you Titanium Backup not working keep saying i'm not rooted
Damn...it feels like the boot-up speed quadrupled at least. My phone literally goes from completely off to fully on and fully responsive within like 5 seconds. This pure coincidence or anyone else have the same?
Big Edit: Ran into a couple weird issues.
1. When I tried to flash the root in recovery after I had got s-off it it kept saying the operation was failing. Eventually after like 3-4 times I decided to try again later and started scrolling through my apps just messing around. I then saw I had somehow got Superuser even though it was saying it had failed. I tried Titanium backup and Setcpu and both worked. So...uh, is it supposed to work like that?
2. I couldn't get into recovery when I powered down the phone at first. Tried it like 3-4 times (volume down + power). I had to pull the battery then try it. It worked after that, but only once or twice. Afterwards I had to pull the battery again to get into recovery.
3. My phone was deactivated for a little bit. Eventually I pulled the battery and when I turned it back on it started doing a hands-free activation which then worked and allowed me to make calls again. Possibly I made a mistake in putting in the S/N or something? I don't think I did but *shrug*.
Anyone else have these?
gulbhahar36
