If you wanted rooted ZVJ Radio and ROM, then I was suggesting you revert to ZVD.Ok, so reference section option a is the way to go? I think I will want to go with gingerrom with gingerkernel to see if that works for me for now.
Then use Option A in the first post to root it.
Then use Option B in the first post to install ZVJ and root.
Option A in the reference section (2nd post) is something you would install after getting the ZVJ radio (or if you currently had the ZVH radio), though most people would probably want the ZVJ radio.
