[How-To] Automated Rooting of LS670ZVD/ZVH/ZVJ
Okay, so I have an Optimus V, and I put Optimus S zvd firmware on it and rooted it. After putting zvj on it using the optiauto tool, trying to root it I get this:
Code:
Installing persistent root... write: No space left on device
Done
Waiting for filesystem to sync... Done
Installing Recovery - Xionia CWMA... write: No space left on device
Done
Installing Misc - Clean... write: No space left on device
Done
---- END LOG ----
I followed the directions precisely. Not sure what I'm doing wrong. Anybody have an answer?
If I factory reset/wiped data and wiped cache right before the install su step, would that work?
did you update your phone?
Sent from my Transformer Prime TF201 using Android Central Forums
About tree fiddy.
Been a long time since I've heard that one. But yes, the welcome guide sticky is where you want to go. Its a great resource for beginners.
Let me ask a silly question: if I have the custom recovery now, and had a rooted zvj nand backup (before I installed first custom rom), do I need to install a stock recovery in order to restore that nand backup file (going back to a rooted stock system)? I tried to do it in the custom recovery but after rebooting I was stuck at sprint logo.
You shouldn't have to use a stock recovery to restore a nandroid. Nandroids have a habit of taking an extremely long time to boot up after being restored for the first time. Are you sure it was stuck at the sprint logo, or was it just taking it's sweet time? (I remember having to wait 10+ minutes on one occasion, but I think it also depends on the quality of your sd card). What happens when you try it again?
Very new to all of this, So I thank you for making it VERY simple for me. Now to decide where to go from here.Thank you!​
Pardon a NOOB question, but if I want to go from rooted ZVJ back to rooted ZVD, what's the process? Is it as simple as running optiauto again and choosing option A (and following the rest of the instructions), or do I need to go through the hassle of unrooting and returning to stock, then rooting ZVD again? I've already got rooted ZVJ, but I wanted to try Quattrimus - and apparently that can only be installed with a ZVD baseband.
I'm having problems on step C. When it goes to install persistant root it says operation is not permitted. Any ideas?
As above, make sure you're following the steps to the letter. Check what baseband you're currently on (by loading into Android an going to About Phone) and make sure you're on ZVD. If you're not, you have to follow the instructions to install the ZVD baseband, root, upgrade by push, and then install whatever ROM you want. that is, if you want to upgrade. It's not necessary with Nitestalker's patches.
I do option A and get at the end when I look up at the log it says "[+] Rush did it ! It's a GG, man !" I then hit ay button to reboot and every time it reboots the phone completely to Android. So I have done this over and over again about 15 times and every time I get the same above message but it reboots to Android. So for the heck of it I shut it down and went into recovery and I can say that it installed the recovery software but when I follow the rest of the instructions and try and load the update, it throws the error
"E:Can't open /sdcard/update.zip
(unknown error: 0)
Installation aborted."
I have downloaded the package multiple times as well. I am curious if I am doing something wrong?
The phone was ZVJ but I used the thread mentioned above to downgrade to ZVD and that worked fine.
Option a ONLY roots the device. You then need to continue thru the guide to proceed further. Check if you now have superuser in your app drawer.
OK, because the instructions make it seem like it does more if you read through option A. Yes I have superuser. After I get root do I go on to Option B, because Option A says to run the update which is failing. Sorry, this is where I am getting confused. I have rooted 4 other phone models with no issues, I guess there is a first time for everything.
From where you are now, start from where you are now and follow the below exert from the OP. Note, there are steps bellow that are not completely automated. Follow the guide EXACTLY word for word. This package does work, I have used it myself several times! Good luck, and let us know if you get stuck again.
0) Backup anything important
It is good practice to backup before making any changes.
ZVH/ZVJ radios appear to be interchangeable, so if after installing the rooted ZVJ, you are not happy, you should be able to restore a ZVH nandroid backup and have it work. ZVD ROMs will not work with ZVH/ZVJ Radios nor will ZVH/ZVJ ROMs work with ZVD Radios.
1) Pre-requisites Checklist
SD card is INSERTED
USB Debugging is ENABLED - [Menu->Settings->Applications->Development->USB debugging]
USB Storage Mode is OFF - [Drag down the notification bar and tap on "USB Connected", should be GREEN]
LG USB/Android drivers are INSTALLED - [See Reference Section D1 (below)]
Phone is connected to USB port and recognized
2) Download the Optimus automated rooting package
optiauto-sfx.exe [mirror1] [mirror2]
optiauto.zip [mirror1] [mirror2]
With the -sfx.exe self-extractor for windows, just run .exe (ie SKIP Step #3)
With the .zip version download and UNZIP to top-level directory of your C: drive
Note #1: zergrush is a known exploit being used to root your phone. Your Anti-Virus software may quarantine or cause the download to be incomplete. Disable your Anti-Virus software if needed so the download can complete. This is only important if you plan on using the tool to root your ZVD/ZVH ROM.
3) Run the Optimus automated rooting package
From PC command prompt, run "runfirst":
(if you have an aversion to typing, you can use file explorer to navigate to C:\optiauto and double-click on RUNFIRST.bat)
4) Select Option to Install Root - ZVJ
Select Option B - Install Root - ZVJ (after ALL steps complete, you will have installed ZVJ update, persistent root and Xionia CWMA recovery)
You will be presented with the following menu:
http://forums.androidcentral.com/attachment.php?attachmentid=23484&d=1334184489
5) Proceed through the options sequentially
This is a PARTIALLY AUTOMATED script. You need to COMPLETE ALL STEPS A-C in SEQUENTIAL ORDER to be rooted with ZVJ.
In the menu system (R) indicates your phone is booted into Recovery for that step. (A) indicates your phone is booted into Android for that step.
You must ALREADY BE ROOTED on your existing ROM to run this successfully.
Code:
Step A.  (A) Install ZVJ recovery / Reboot Recovery
Step A - while booted into Android, select Option A in the OptiAuto tool. Assuming you are rooted, this will install the ZVJ Recovery and place the ZVJ update.zip on your phone. It is VERY IMPORTANT that the ZVJ Recovery installs correctly so pay attention to the status logs. If there is an error, it needs to be fixed before continuing. You can repeat this step as many times as necessary as long as you don't continue to the next step.
After Step A is complete the phone will automatically reboot to Recovery. The automatic reboot works most of the time, but sometimes it will boot back to Android. If it boots back to Android, just repeat Step A.
Once in Recovery you need to perform the steps listed in the Menu ON YOUR PHONE within Recovery (within Android for the last step):
Code:
Perform on Phone (should be in Recovery, if not, REPEAT last step)
1. (R) wipe data/factory reset  (OPTIONAL/HIGHLY SUGGESTED)
2. (R) apply sdcard:update.zip  (2-5 min, installs ZVJ)
3. (R) reboot system now        (reboot menu option in Recovery)
4. (A) RE-ENABLE USB Debugging  (Press Menu to skip Activation)
The "wipe data/factory reset" is OPTIONAL, but HIGHLY SUGGESTED
Next, choose "apply sdcard:update.zip". This will install ZVJ. After running this step you will NO LONGER HAVE ROOT. Please do not run this step UNTIL YOU ARE SURE Step A (above) completed successfully.
When the update is complete (around 2-5 min) select "reboot system now" in the Recovery menu. This will write the ZVJ Radio and boot into Android.
Once in Android, you will find that USB Debugging has been disabled. Press the "Back" button on the phone a few times to exit the Mass Storage screen and the Initial Configuration Wizard. If you get stuck in Hands Free Activation or Sprint ID selection, Press "Menu" to Skip. Then go and enable USB Debugging
Now you are ready to select Option B
Code:
Step B.  (A) Reboot Recovery (REPEAT STEP if this boots to Android)
Step B - this will copy a new update.zip to your phone and automatically reboot to Recovery. Sometimes the reboot to Recovery doesn't work and you end up in Android. If this happens just REPEAT this step. This step can be repeated as many times as necessary.
Once in Recovery
Code:
1. (R) apply sdcard:update.zip  (SHOULD say INSTALLATION ABORTED)
       DO NOT REBOOT, proceed to next step
You must apply the update.zip. It SHOULD say INSTALLATION ABORTED. This is an expected error. Do not reboot phone, proceed directly to Step C
Code:
Step C.  (R) Install Root (INSTALL su, busybox, Xionia CWMA Recovery)
Step C - your phone should still be in Recovery. This step will install persistent root and Xionia Recovery, then automatically reboot your phone. After this step completes successfully, you will be rooted on ZVJ with Xionia CWMA custom recovery installed! This step can be repeated as many times as necessary.
Note #1 - If you get stuck waiting for the phone to connect, REBOOT your phone AND PC and try again.
6) You are DONE!
I do apoligize it is confusing because he says follow option A but then he never really tells you where option A starts. Thank you very much I will see if this works.
r3dpuk3
