how to completely remove google from android phone
Status
Not open for further replies.
Actually android is an open source operating system. It is based on the Linux operating system. The source code can be downloaded altered and compiled for any comparable device. Google does not "own"android. Your phone will operate, third party apps will run, Google Chrome will run, etc without Google services. Anything you need to do can be done from a browser. Please do not offer advice if you don't know what you're talking about.
Welcome, first time poster. O_o
Who are you responding to? I know very well the difference between AOSP and conventional Android releases. Do you?
The op (three years ago!) wanted to delete files in order to "stop the heartbeat." That belies a naivete about how modern digital cell phones work. They are constantly checking in with the network.... The simple answer under Android 5.0 is to turn off all syncing and use the phone as a standalone device.
Deleting files is probably going to cripple some of the OS functions, not something I'd recommend then or now.
Status
lilyo7788
