- Jan 16, 2011
- 89
- 0
- 0
I posted this on XDA website too. Just trying to get as much information as possible on how to correctly charge a lithium battery.
I don't know if the article I found correctly indicate the fact. Here is my way to charge my nexus 4 or 7
1. I never let my battery drain to zero or shut itself down. I usually charge when it's 10% or over 5% (How's your view about it? too low?)
2. I rarely fully charge my phone to 100%. I usually get it done around above 95.
3. I "turn off" the device while I'm charging. In this case, I turn off Nexus 4 and 7 when I need to charge them.
4. I rarely charge my phone overnight...( any second opinion on this?)
Any views and suggestions are all welcome. I just try to find the best way on how to "correctly" charge our nexus 4 lithium polymer battery.
Here is an article I read as an example How to Properly Charge your Cell Phone Battery | ChargeAll
Few questions here.
1. Can you charge as often as you want? Since Lithium battery doesn't have "memory"..? Is this true that you can charge whenever you want?
2. Can you charge your phone overnight?
Few questions here.
