How to disable double tap unlock during calls on s7 Edge?
  • Start date Start date
A
Android Central Question
During Incoming/Outgoing calls , instead of screen off , I recieve double tap to unlock which is annoying? Kindly help me out
I have also faced the same problem but i have sorted it out. So just go to
-Mobile settings,
-Then open accessibility.
-There you will find "Pick to answer" option.
Just enable that option. So after that whenever you will get a call, you don't have to double tap the screen, instead just put the speaker near your ear the call will be picked automatically.
