how to eject/umount USB stick
tonyvr4
194
I have two firesticks (2nd gen and a 4K) with both using a OTG power Y cable.
I can access the USB thumbdrive plugged into the cable on both and access the files.
But I can not find a way to safely eject or unmount the thumbdrive.
If I unplug the drive I get an error message saying to go to my firetv/settings/storage and select USB to eject.
But there is no USB listed in any settings menu
If I plug the thumbdrive into the computer I get an error and it scans and fixes it.
How can I safely remove the USB drive from the firestick?
Miserydhala
