I was asked how I did it, so I put together this video. Hope it helps..
https://youtu.be/FSLbzsrXDHQ
I can't get it to work its driving me crazy
Which email client are you using?I installed the app on my S10+ and set it up just the way the video showed, but it doesn't work at all for email. That's what I really needed it for.
Is it supposed to work for email?
Try this.I can't get the notification to repeat despite following the video. Any thoughts?.
Click this to get gmail.I do not see GMail as an alert option.
Mav.![]()
Spectacular.Click this to get gmail. //uploads.tapatalk-cdn.com/20190313/2348c885d577652d31c39ace6d40c122.jpg
Yahoo.com and sbcglobal.net
You have to enable an app in the settings. I am not sure if you are going to a website to access what you mentioned or not. I can tell you it works for Gmail and Outlook.Yahoo.com and sbcglobal.net
