How to enable LED light around camera cutout and more!
I like just wish was a setting to stay on continuously until I pick up phone
Will this also work while the AOD is on? I had some notifications I enabled and all permissions and it didn't turn on with AOD.
Can we just get instructions rather than a video? There's nothing I hate more than constantly rewinding a video to get something I need clarification on.
I witnessed a notif from Gmail. Looks like it works. This app doesn't mess with any settings like sync or anything does it? Those four permissions you had to give it at the very top of this app seems like it has the ability to turn off like DND and stuff like that.
Ok, I get it replaces AOD, however when I try to select all apps for them to show default colors it's always white. I check select all, then hit back button but I see it uncheck itself before I can save it. I'll just have to use the rainbow effect I guess.
The one app I really need to have show light is the stock email app. I can't find it in the list of apps when trying to enable apps in the settings.
Now if the creator can come up with a way to have the notch light up when the device is off and charging, I'd be a happy man.
Mav. :cool:
I've got it working for messages but not for missed calls...I have four rows of "Phone" in the Enable Apps dialog. I have then all checked. Should I be enabling something else?
I'm having the same exact problem, no idea how to get a notification for a missed call.
I have the notch to light up when charging. How do I get the screen to stay OFF and keep notch lighting.?
djdjjkzzz
