HOw to fix? "MMS could not be delivered due to insufficient funds" ...WRONG
cognus
121
hi friends this issue is new to me, not new to many others apparently. I have a Note 1, on T-mobile for about a year now. occasionally I would get a bad MMS send or receive, usually remedied by deleting the offending thread, then trying it all over again. usually second try would work.
not now.
about a month back started having MMS messages "hang" where the send/receive would be trying to complete and never could, no matter where I was, on wifi or cell or whatever. but no error message, it just would never process. Then about 4 days ago I start getting "your MMS could not be delivered due to insufficient funds", however my usage is no where near the ceiling.
contacted t-mobile twice - a huge waste of time. can't get to anyone competent. they say there's no issue... after an hour of goonish reset this and reset that.
any clues? I tried Tweakker... makes no diff whatsoever. not sure the app works at all.
is there way to somehow reset all network-related settings without reinstalling rom? i have seen such on other handsets but do not see such on this one.
any other messaging apps that have a way to remedy this?
thx
thanks for the reco.
does this require that the recipient install anything on their end so that I can communicate with them? or is it "push"able?
They need to install it too. Most people already have it. It's basically free mms over wifi or data plan.
Sent from my GT-N7000 using Tapatalk 2
Michael4444
