HOW-TO flash your GSM G Nex to takju with root
ok , so first I had the same error as randytherobot until I realized that I didn't type the word bootloader twice as it should be...but now I'm stuck right after the first command , it says "waiting for device" and won't move on , I checked everything a couple of times and just can't find any mistake ...any idea what might be wrong ?
cheers
At one time I got the "waiting for device" and I ended up having to install the drivers from Samsung and/or enabling USB debugging on my phone to get it to work. I don't have the link for the drivers anymore, but I found it by searching. You might want to try enabling the USB debugging first and see if your computer installs the drivers automatically. You need to make sure your computer recognizes the phone appropriately.
Correct drivers and having them set up properly is 90% of the battle. Multiple drivers or old drivers WILL cause problems. I had no success until I got rid of any driver that could possibly be causing a conflict, and started fresh... took a few tries to get it working, but that was the hardest part
Vector
