How to get ICS if you are stuck
I am trying to get the RUU to run to revert my phone from the .10 leak back to GB so I can download the official .12 update.
But when I try to run the ruu.exe I get an error that my phone is not connected to the computer, but everything is set as it should be and the phone even shows fastboot USB....
Sent from my ADR6425LVW using Tapatalk 2
Just curious why u r going back,when u can flash the .12 leak,and get all the future updates.
sent from my iced up&jellybeanless,HTC REZOUND
now we get to the root of the issue...
You CANNOT go back unless you are s-off.
If you are not the only thing to do is my OP
I am trying to do what you posted in original post.
If that is the case, why can't I get the ota now?
You need to be s off to go from a leak to gb.... From one ics to another you do not need to be
Sent from my ADR6425LVW using Android Central Forums
Ahhh, I just now caught this. Ok, I guess I just need to update to the .12 leak. I see that now, sorry for my confusion.
So, where do I get the leak? LOL
I am working on a new host, but if you want it is on Android police... It will take forever to download....
I downloaded from your link and it downloaded fine...
CathyAus
