How to get iTunes music library into Note 3
Re: How to get itunes music library into Note 3
I just tried Easy Phone Tunes and it loaded all of my music except the songs that I purchased. Will isyncr load the purchased songs?
Some songs will not sync if they are protected. As a general rule, the older songs you paid .99 for are probably protected. The ones you paid 1.29 for should sync.
Sent from my iPad using Tapatalk HD
Sounds great but what are the steps to do that? I'm looking at Google Music and see nowhere to import or sync anything.
Bingo! Been using this too. Works well but it takes a while before it can sync while it enumerates the library (1-2 minutes) in my experience. However, it works consistently well.
The Note III
I completely agree. Just used it last night on my Note 3
iceteanice
