trucksmoveamerica#AC
Trusted Member
- Jul 20, 2010
- 8,534
- 1,217
- 113
Use the bk package disabler, it works and no hooking the computer up, easy peasy, just the way I like it
They want to disable stuff that they don't use to save battery.Why are you guys using Package Disabler? This is one app that actually ruins the phone
Yep, I get that.They want to disable stuff that they don't use to save battery.
