How to install S-Voice to galaxy nexus
i installed the hacked version, through CWM, on my galaxy nexus running slim ICS. S voice will open up, then keep giving me network errors every time i try to speak to it. i've already tried the build.prop fix, what else can/should i do to get this working? thanks.
davehzrd, try this one. I was getting the same error on a previous version but this one is working fine for me
thanks, i tried that version and it still wasn't working at first. what eventually got it working was installing both vlingo and S voice. i don't know if there are some system settings that vlingo changes that allow S voice to work, but whatever the case, i'm in business now. i just sat down with my brother and pitted my S voice against his siri, and even had the one-up on him in a few places. :)
Very nice. Are you able to set alarms? This seems to be the only thing I cannot do with S Voice.
i had to install a new clock program, you can get it here i think:
http://www.mediafire.com/?8latws7lht4uuxf
it's basically the clock from the galaxy S3, turned into a .zip file so you can flash it onto any android phone while you're in recovery mode. it replaces the stock ICS clock, which is fine because the stock android clock was a pain in the neck to set alarms on. i much prefer typing in alarm times (or telling S voice to set them!) instead of having to spin the stupid dials around. i really hated setting alarms on the stock ICS clock, it was about as user-friendly as a backwards pointed gun.
I have flashed the new clock program and have the signed voice apk installed, but tasks still won't set. I have not yet tried to the hacked zip file from xda. Is this the one that I need to get the tasks to work, or should it work with the signed apk that has been floating around?
I still cannot set an alarm with S Voice. Flashed the new clock and it seems as though it didn't take.
Winnix
