How to keep ethernet connection from dropping when phone goes to sleep?
  • Start date Start date
A
Android Central Question
I use ethernet adapter to connect my Galaxy S10e to the LAN cable and turn on Wi-Fi hotspot to get a decent Wi-Fi signal in my room, while charging the phone simultaneously on a Qi charger. But when the phone gets to 100% and stops charging for a bit, ethernet connection drops and so does my internet now. I tried to keep the display on using Tasker, but even that requires the phone to be charging in some way to keep the display on. How do I fix the issue?
Hi , if you can register a account here , me or other members be happy to assist.
I'll provide a link to register so you can communicate here.https://forums.androidcentral.com/ask-question/409154-join-android-central-community.html
Look in the Ethernet adapter's app (there should be one) for a setting that allows it to go to sleep under certain conditions (fully charged, screen off, sleeping, whatever). Turn that off.
Buy a decent WiFi router.
Or a WiFi switch to plug your Lan cable into.
You're causing yourself problems by overcomplicating a problem with a simple solution. You'll also wreck your phone doing this long term.
Hokaso Shaikh
