How to keep your phone from making the annoying camera sound
jtabb1256
4
I find the camera sound very annoying on my phone, and even if it's on silent, it plays the camera sound. This is how to remove the camera sound.
1. Using a file explorer, I recommend es file explorer or root explorer, go to /system/media/audio/ui and there you will see 2 camera files.
2. Copy and Paste them into your sd card, then delete them from /system/media/audio/ui
3. This will keep your phone from making the camera noise. :)
Or you can just turn your Media volume down, since the Media volume is what governs the camera app's sound. Setting your phone to silent doesn't affect Media volume, which is why silent doesn't work.
SwiftKeyed/Flowed via TapaTalk 4 beta.
"Or you can just turn your Media volume down, since the Media volume is what governs the camera app's sound. Setting your phone to silent doesn't affect Media volume, which is why silent doesn't work."
For my particular phone, even if I turn down every volume there is, it will play the camera sound.
