[How-to] Revert to LS670V9, after installing OTA LS670VC/VD, using KP500 (Diag mode)
and how i can check if my phone case with VC??
The OTA updates only upgrade one version at a time. If you accepted only 1 update and are currently at VD, then you were previously at VC. If you accepted 2 or more OTA updates, then you were on V9 or earlier.
To see your current version, look at menu->settings->about phone
so you think i should follow the instructions on page 1 and flash my phone to v9 and then to vc?? or are there any instructions to flash it back directly to vc?? i really appreciate your help...
If you want VC, then just flash directly to VC using the substitutions in the reference section. There is no need to flash V9 first. The instructions default to V9 because that is what people flash to get rooted.
after revert to vc, phone worked fine, hot spot worked, but then i got prompt to update again, i clicked on more info , shut off my phone replace battery and restart again and its now stuck on LG logo from last 15 minutes... any idea what went wrong and what are my options ...???
I know what you are describing but haven't heard of it happening in the sequence you described.
You could try the "unbrick" thread to try and flash in emergency mode.
http://forum.androidcentral.com/lg-...s/59781-un-brick-method-some-forms-brick.html
Has anyone tried this lately. Trying to revert my mothers phone back to V9 from VD so she can use her wireless tether again. I've been running TR on my phone since November, and went thru the whole LG updater going from V9 to VD a few months ago with no problem. She accepted the OTA VD update, so of course I am trying to use KP500 to force flash V9.
All drivers are updated. LG update tool is up to date. ADB reads and is communicating with her phone. LG Updater is acting like its communicating with phone and has reset it in while analyzing. Steps have gone seamlessly until p) and the LG updater gives me this:
20:19:56 : ******Extract Start n*****
20:19:56 : Model Dll Dir(C:\ProgramData\LGMOBILEAX\Phone\)
20:19:56 : ExtractInfo Error(0)
20:19:56 : Extract cab file error.
20:19:56 : [C:\ProgramData\LGMOBILEAX\Phone\BIN] ???丮 ???? ?õ?
20:19:56 : RemoveDirectory1 Error(5):C:\ProgramData\LGMOBILEAX\Phone\BIN
20:19:56 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
20:19:57 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
20:19:57 : CLGMobileHttp Class ?Ҹ????.
20:19:57 : CLGMobileHttp Class ?Ҹ?...
20:19:57 : Page_Error ?κ??Դϴ?
20:19:57 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
I know one solution to the "extractinfo error/extract cab file error" is making sure its named right. Ive checked thru cmd to make sure that my cab file is named correctly and isn't cab.cab like some individuals were mentioning.
The LG phone updater is giving me this error:
Updating is not possible any longer due to a fatal error while the LG Mobile Phone Software Update
then says something like select contact button for LG Mobile Phone Software Update online.
Anyone have any ideas?
Having trouble updating from v9 to vd please help
THIS IS THE ERROR MSG FROM KP500 SOFTWARE THAT I RECEIVED WHEN I TRY TO UPDATE
21:45:19 : [C:\LGMobileUpgrade] ???丮 ???? ?õ?
21:45:19 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
21:45:19 : Start Date : 2011-04-16 21:45:19
21:45:19 : -------- Buyer Test mode ---------
21:45:19 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
21:45:19 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
21:45:19 : *****CheckOS Start********
21:45:19 : Microsoft_Windows_Vista Home Edition_
21:45:19 : *****CheckPCSyncPrograms Start*****
21:45:20 : PCSyncPrograms Not Found
21:45:20 : SetEmerModeAT()
21:45:20 : _IsConnectedPhone Call
21:45:25 : _IsConnectedPhone(1)
21:45:25 : 0 - NotConnected.
21:45:25 : 1 - Normal connect success
21:45:25 : 2 - Emergency connect success
21:45:55 : Checking the connection with the cell phone...
21:45:55 : dwWaitResetTime(40000 ms)
21:45:56 : Phone Mode(1)
21:45:56 : *****GetPhoneType Start*****
21:45:58 : Phone Type : CDMA
21:45:58 : *****Start GetPreviousStep*****
21:45:58 : _GetPreviousStep(dwStep:0xffff)
21:45:58 : _SetPhoneNumber retval=1
21:45:58 : *****GetPhoneModel Start*****
21:46:00 : *****GetPhoneBinaryVersion Start*****
21:46:00 : Phone Bin Version : LS670ZV9_20
21:46:00 : *****Get ESN / IMEI / MEID Start*****
21:46:03 : ESN/IMEI/MEID : A00000284C5372
21:46:03 : *****GetPhoneNumber Start*****
21:46:05 : Phone Number : A00000284C5372
21:46:06 : ???? ?˻? ?Ķ??Ÿ - ESN_IMEI : A00000284C5372, Model :
21:46:06 : *******CheckBinVersion***************
21:46:06 : New Bin Version(LS670ZVD), Current Ver(LS670ZV9_20)
21:46:09 : _GetAuthMark : wAuthMark(30312)
21:46:09 : Wait 3Sec
21:46:14 : _SetAuthMark Ok : wAuthMark(30312), PhoneMode(1)
21:46:14 : *****Start _GetBatteryLevel*****
21:46:17 : Battery(5)
21:46:18 : ResetPhone...
21:46:18 : Checking the connection with the cell phone...
21:46:18 : dwWaitResetTime(40000 ms)
21:46:48 : _IsConnectedPhone Call
21:46:54 : _IsConnectedPhone(1)
21:46:54 : 0 - NotConnected.
21:46:54 : 1 - Normal connect success
21:46:54 : 2 - Emergency connect success
21:46:54 : Phone Mode(1)
21:46:54 : m_dwBootWaitTime(35603)
21:46:54 : Checking the connection with the cell phone...
21:46:54 : dwWaitResetTime(30000 ms)
21:47:24 : _IsConnectedPhone Call
21:47:30 : _IsConnectedPhone(1)
21:47:30 : 0 - NotConnected.
21:47:30 : 1 - Normal connect success
21:47:30 : 2 - Emergency connect success
21:47:30 : Phone Mode(1)
21:47:30 : Call _ModeOffline()
21:47:31 : *****CheckPCSyncPrograms Start*****
21:47:31 : PCSyncPrograms Not Found
21:47:32 : CLGMobileHttp Class ?Ҹ????.
21:47:32 : CLGMobileHttp Class ?Ҹ?...
21:47:32 : ****************CheckAndDownload********************
21:47:32 : ******Extract Start C:\LS670ZVB.SD_12_12.P60675*****
21:47:32 : Model Dll Dir(C:\ProgramData\LGMOBILEAX\Phone\)
21:47:32 : ExtractInfo Error(0)
21:47:32 : Extract cab file error.
21:47:32 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
21:47:32 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
21:47:33 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
21:47:33 : CLGMobileHttp Class ?Ҹ????.
21:47:33 : CLGMobileHttp Class ?Ҹ?...
21:47:33 : Page_Error ?κ??Դϴ?
21:47:33 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
Yes I am getting something pretty similar:
20:18:03 : [C:\LGMobileUpgrade] ???丮 ???? ?õ?
20:18:03 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
20:18:03 : Start Date : 2011-04-16 20:18:03
20:18:03 : -------- Buyer Test mode ---------
20:18:03 : [C:\ProgramData\LGMOBILEAX\Phone\BIN] ???丮 ???? ?õ?
20:18:03 : RemoveDirectory1 Error(5):C:\ProgramData\LGMOBILEAX\Phone\BIN
20:18:03 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
20:18:03 : *****CheckOS Start********
20:18:03 : Microsoft_Windows_Vista Home Edition_
20:18:03 : *****CheckPCSyncPrograms Start*****
20:18:03 : PCSyncPrograms Not Found
20:18:03 : SetEmerModeAT()
20:18:03 : _IsConnectedPhone Call
20:18:09 : _IsConnectedPhone(1)
20:18:09 : 0 - NotConnected.
20:18:09 : 1 - Normal connect success
20:18:09 : 2 - Emergency connect success
20:18:20 : Checking the connection with the cell phone...
20:18:20 : dwWaitResetTime(40000 ms)
20:18:21 : Phone Mode(1)
20:18:21 : *****GetPhoneType Start*****
20:18:23 : Phone Type : CDMA
20:18:23 : *****Start GetPreviousStep*****
20:18:23 : _GetPreviousStep(dwStep:0xffff)
20:18:23 : _SetPhoneNumber retval=1
20:18:23 : *****GetPhoneModel Start*****
20:18:25 : *****GetPhoneBinaryVersion Start*****
20:18:25 : Phone Bin Version : LS670ZVD_12
20:18:25 : *****Get ESN / IMEI / MEID Start*****
20:18:28 : ESN/IMEI/MEID : A000002848B491
20:18:28 : *****GetPhoneNumber Start*****
20:18:30 : Phone Number : A000002848B491
20:18:31 : ???? ?˻? ?Ķ??Ÿ - ESN_IMEI : A000002848B491, Model :
20:18:31 : *******CheckBinVersion***************
20:18:31 : New Bin Version(o), Current Ver(LS670ZVD_12)
20:18:33 : _GetAuthMark : wAuthMark(31355)
20:18:33 : Wait 3Sec
20:18:39 : _SetAuthMark Ok : wAuthMark(31355), PhoneMode(1)
20:18:39 : *****Start _GetBatteryLevel*****
20:18:41 : Battery(5)
20:18:43 : ResetPhone...
20:18:43 : Checking the connection with the cell phone...
20:18:43 : dwWaitResetTime(40000 ms)
20:19:13 : _IsConnectedPhone Call
20:19:18 : _IsConnectedPhone(1)
20:19:18 : 0 - NotConnected.
20:19:18 : 1 - Normal connect success
20:19:18 : 2 - Emergency connect success
20:19:18 : Phone Mode(1)
20:19:18 : m_dwBootWaitTime(35545)
20:19:18 : Checking the connection with the cell phone...
20:19:18 : dwWaitResetTime(30000 ms)
20:19:48 : _IsConnectedPhone Call
20:19:54 : _IsConnectedPhone(1)
20:19:54 : 0 - NotConnected.
20:19:54 : 1 - Normal connect success
20:19:54 : 2 - Emergency connect success
20:19:54 : Phone Mode(1)
20:19:54 : Call _ModeOffline()
20:19:55 : *****CheckPCSyncPrograms Start*****
20:19:55 : PCSyncPrograms Not Found
20:19:56 : CLGMobileHttp Class ?Ҹ????.
20:19:56 : CLGMobileHttp Class ?Ҹ?...
20:19:56 : ****************CheckAndDownload********************
Just a thought and hopefully not the case, but what are the chances that through these threads LG has figured out what we are doing as far as force flashing different versions to gain root, update without losing root, etc. and has block out path? I don't know why LG would care so I wouldn't think this is the case and I'm sure were missing something basic.....atleast I hope so.
rcr0413 are you rooted already on V9? If so you shouldn't have to use KP500 to upgrade to VD, atleast I didn't. All you have to do is is us LG Updater tool to upgrade.
If I recall steps are as follows, but there are different threads in here that talk about it.
1)Nand back up your current settings in your custom recovery.
2)Place whatever custom ROM you want on the root of your SD card
3)Use LG Upgrader tool to upgrade from V9 to VD. Once upgrade is complete phone completely reboots. Once is rebooted power phone off.
4) Power into your custom recovery with the volume down, home, and power button combo. Make another nandroid backup. Flash whatever VD custom rom (ThundeRom, Nrom, etc.) you want to run in your custom recovery. Reboot from there and you should be good to go.
Those steps worked for me, but again I'd search the threads because its explained elsewhere.
Both your errors have to do with a problem with the cab file or filesystem. It could either be:
1) cannot find file
a) not in the same directory as KP500
b) renamed improperly (even if it looks ok under windows explorer)
2) file problem
a) corrupted cab file
b) incomplete cab file
3) file system problem
a) permission problem
b) out of space problem
c) create directory problem
Eventually you'll figure it out and in hindsight it'll be obvious what was wrong, but until then it'll seem like everything was done correctly. I don't say that for all errors, but with this particular one, that has been my experience.
I suggest going back through the instructions, paying special attention to steps (e) through (i)
Thanks for the advice. Ill start everything over next time I have her phone and run check sum as well. My cab file could have gotten corrupted, who really knows yet.
Sent from my NookColor using Tapatalk
i ran fsum it matches what the instuctions say, if the .cab is corrupt this would not match correct? oh and this is my log:
error log
16:58:39 : [C:\LGMobileUpgrade] ???丮 ???? ?õ? 16:58:39 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade 16:58:39 : Start Date : 2011-04-17 16:58:39 16:58:39 : -------- Buyer Test mode --------- 16:58:39 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ? 16:58:39 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone 16:58:39 : *****CheckOS Start******** 16:58:39 : Microsoft_Windows_Vista Home Edition_ 16:58:39 : *****CheckPCSyncPrograms Start***** 16:58:39 : PCSyncPrograms Not Found 16:58:39 : SetEmerModeAT() 16:58:39 : _IsConnectedPhone Call 16:58:45 : _IsConnectedPhone(1) 16:58:45 : 0 - NotConnected. 16:58:45 : 1 - Normal connect success 16:58:45 : 2 - Emergency connect success 16:59:06 : Checking the connection with the cell phone... 16:59:06 : dwWaitResetTime(40000 ms) 16:59:07 : Phone Mode(1) 16:59:07 : *****GetPhoneType Start***** 16:59:10 : Phone Type : CDMA 16:59:10 : *****Start GetPreviousStep***** 16:59:10 : _GetPreviousStep(dwStep:0xffff) 16:59:10 : _SetPhoneNumber retval=1 16:59:10 : *****GetPhoneModel Start***** 16:59:12 : *****GetPhoneBinaryVersion Start***** 16:59:12 : Phone Bin Version : LS670ZVD_12 16:59:12 : *****Get ESN / IMEI / MEID Start***** 16:59:15 : ESN/IMEI/MEID : A0000028DFE667 16:59:15 : *****GetPhoneNumber Start***** 16:59:17 : Phone Number : A0000028DFE667 16:59:17 : ???? ?˻? ?Ķ??Ÿ - ESN_IMEI : A0000028DFE667, Model : 16:59:17 : *******CheckBinVersion*************** 16:59:17 : New Bin Version(LS670ZV9_20), Current Ver(LS670ZVD_12) 16:59:17 : ?ֽ? ?????̹Ƿ? ???׷??̵带 ?? ?ʿ䰡 ????. 16:59:20 : _GetAuthMark : wAuthMark(2739) 16:59:20 : Wait 3Sec 16:59:26 : _SetAuthMark Ok : wAuthMark(2739), PhoneMode(1) 16:59:26 : *****Start _GetBatteryLevel***** 16:59:28 : Battery(5) 16:59:29 : ResetPhone... 16:59:29 : Checking the connection with the cell phone... 16:59:29 : dwWaitResetTime(40000 ms) 16:59:59 : _IsConnectedPhone Call 17:00:05 : _IsConnectedPhone(1) 17:00:05 : 0 - NotConnected. 17:00:05 : 1 - Normal connect success 17:00:05 : 2 - Emergency connect success 17:00:05 : Phone Mode(1) 17:00:05 : m_dwBootWaitTime(35600) 17:00:05 : Checking the connection with the cell phone... 17:00:05 : dwWaitResetTime(30000 ms) 17:00:35 : _IsConnectedPhone Call 17:00:40 : _IsConnectedPhone(1) 17:00:40 : 0 - NotConnected. 17:00:40 : 1 - Normal connect success 17:00:40 : 2 - Emergency connect success 17:00:40 : Phone Mode(1) 17:00:40 : Call _ModeOffline() 17:00:41 : *****CheckPCSyncPrograms Start***** 17:00:42 : PCSyncPrograms Not Found 17:00:43 : CLGMobileHttp Class ?Ҹ????. 17:00:43 : CLGMobileHttp Class ?Ҹ?... 17:00:43 : ****************CheckAndDownload******************** 17:00:43 : ******Extract Start C:\LS670ZV9.cab***** 17:00:43 : Model Dll Dir(C:\ProgramData\LGMOBILEAX\Phone\) 17:00:43 : ExtractInfo Error(0) 17:00:43 : Extract cab file error. 17:00:43 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ? 17:00:43 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone 17:00:43 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR 17:00:43 : CLGMobileHttp Class ?Ҹ????. 17:00:43 : CLGMobileHttp Class ?Ҹ?... 17:00:43 : Page_Error ?κ??Դϴ? 17:00:43 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
It did everything like it was supposed to till that point so now the phone has no service but it also did not revert to V9 ??
If your checksum matches, then the cab file is correct. Move on to the other areas I listed.
It could be a permission problem as well. Are you running as administrator or some lower privileged account?
Could you perform the second half of step (h) and post the output?
While you are at it, perform the second half of step (h) and post the output.
Lol not sure how to address the other areas you listed im kind of noobishly dumb, but as for permissions im on an administartors profile, step (h) output? the dir?
(h) dir
C:\KP500-Utils-EN-v0.4.2>dir Volume in drive C has no label. Volume Serial Number is E24B-9178 Directory of C:\KP500-Utils-EN-v0.4.2 04/17/2011 06:46 PM <DIR> . 04/17/2011 06:46 PM <DIR> .. 03/03/2007 09:02 PM 344,064 fsum.exe 02/11/2007 03:37 PM 22,133 fsum_ReadMe.txt 11/14/2008 01:56 PM 155,648 Inf_WebDnld.dll 08/18/2009 03:49 PM 424,960 KP500-Utils-EN.exe 08/03/2009 01:15 PM 86,016 LGMUpgradeDL.dll 04/17/2011 01:50 AM 99,220,700 LS670ZV9.cab 7 Files(s) 100,704,081 bytes 2 Dir(s) 54,049,345,536 bytes free
Also i Turned off power turned on power and service is back to normal
Trying to revert from a Win7 64bit machine
Honestly I'm not sure if it's an OS issue or something else but I figured win7 was still pertinent. I'm having an issue which I am about to post all the logs for while I'm at it I had a second question.
I apologize if this isn't really the right thread for this but:
--Being of a linux background and having played around with several android ports I'm really wondering.
--Is it not possible to flash the revert image using fastboot?(if so this would actually work in windows to but I would prefer to do everything from linux, I trust the computer more)
Regardless of my above curiosity I decided to use the outlined method as it is documented to have worked.
I have installed the LG tool aswell as the drivers for the optimus s. I've confirmed the phone is mounting properly in debug mode in usb by checking deviceman by seeing if ADB was present:
ADB Interface
-Android Platform Sooner Single ADB Interface
I have also confirmed that the LG Android modem is registering
Modems
-LGE Android Platform USB Modem
I confirmed the checksum on the cab file after download and even grabbed yall the dir tree from the KP500 dir:
Volume Serial Number is D6BC-7CC7
04/17/2011 04:18 PM <DIR> .
04/17/2011 04:18 PM <DIR> ..
04/17/2011 04:18 PM 344,064 fsum.exe
04/17/2011 04:09 PM 155,648 Inf_WebDnld.dll
04/17/2011 04:09 PM 424,960 KP500-Utils-EN.exe
04/17/2011 04:09 PM 86,016 LGMobileDL.dll
04/17/2011 04:09 PM 450,560 LGMUpgradeDL.dll
04/17/2011 04:12 PM 99,220,700 LS670ZV9.cab
6 File(s) 100,681,948 bytes
2 Dir(s) 86,765,969,408 bytes free
And well long story short when I actually attempt the flash this is the output I get:
18:28:56 : [C:\LGMobileUpgrade] ???丮 ???? ?õ?
18:28:56 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
18:28:56 : Start Date : 2011-04-17 18:28:56
18:28:56 : -------- Buyer Test mode ---------
18:28:56 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
18:28:56 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
18:28:56 : *****CheckOS Start********
18:28:56 : Microsoft_Windows_XP_Home Edition_
18:28:56 : *****CheckPCSyncPrograms Start*****
18:28:57 : PCSyncPrograms Not Found
18:28:57 : SetEmerModeAT()
18:28:57 : _IsConnectedPhone Call
18:29:12 : _IsConnectedPhone(0)
18:29:12 : 0 - NotConnected.
18:29:12 : 1 - Normal connect success
18:29:12 : 2 - Emergency connect success
18:29:37 : Checking the connection with the cell phone...
18:29:37 : dwWaitResetTime(40000 ms)
18:29:38 : _IsConnectedPhone Call
18:31:51 : _IsConnectedPhone(1)
18:31:51 : 0 - NotConnected.
18:31:51 : 1 - Normal connect success
18:31:51 : 2 - Emergency connect success
18:31:51 : Phone Mode(1)
18:31:51 : *****GetPhoneType Start*****
18:31:51 : [011,700,147,062,092]Updating is not possible any longer due to a fatal error.\n\n[009,400,102,102,102]Disconnect from and connect the cable into your phone again and remove \nand install the battery and press the [009,700,102,102,102]'Restart'[009,400,102,102,102] button. This will resume the \nupgrade.\n\n\n\n\n\n\n\n\n\n\n\n\nPress the [009,700,102,102,102]Quit[009,400,102,102,102] button to stop the update. (_CheckPhoneType() Error)
18:31:51 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
18:31:51 : Page_Error ?κ??Դϴ?
18:31:51 : ????? Retry ?κ??Դϴ?
18:31:51 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
As you can tell I have it running in compat mode for XP, I've tried SPs2 and 3.
I have tried reseating the usb cable before hitting restart aswell as simply attempting to restart, everytime I get the same outcome.
Thanks All.
(h) dir
If you look at the directory listing I provided in step (h), you are missing the following file:
08/03/2009 01:15 PM 86,016 LGMobileDL.dll
Please unpack the KP500 zip file to obtain this file and try again.
Also, it would be difficult for the revert process to have permanently caused the service problem you described as it has not done any writes to your phone, only reads. If it had gotten to the write stage, then it would be possible, though still not likely.
Step (h) from first post
The output of the above "dir" command should look like this:
(make sure you have at least these 5 files, one file is named LS670ZV9.cab and the file size is 99,220,700)
(if your directory does not look like this, STOP here, figure out why)
Volume in drive C is
02/18/2011 12:48 PM <DIR> .
02/18/2011 12:48 PM <DIR> ..
08/03/2009 01:15 PM 450,560 LGMUpgradeDL.dll
02/11/2011 02:10 PM 99,220,700 LS670ZV9.cab
5 File(s) 100,337,884 bytes
Thoitrangyozu
