How to root motorola milestone x2 (2.3.6)
Where would i find them? Ive tried countless rooting methods and factory reset my phone so many times that i noticed some apps dissappeared.
Sent from my Milestone X2 using Android Central Forums
this isnt actually a reply i just wanted to know if anyone could help me!!!!!! i rooted my phone then i downloaded an app called font changer and i did something in the app changing my font now my phone wont load at all i need help badly plz help someone
@Sketch the one I use is absolute system tools. And AS Maid pro those will both clean yur phone and delete unwanted apps.
Sorry was meant to be SD not ( AS ) DAMN predictive text.
@Dnice try retracing yur steps on What you did when you downloaded the fonts and se if you my have changed yur settings by mistake. And if that don't work delete the fonts. Is all I can think of rite now.
Ok so now that we have our X2 rooted heres a big question. How do you unroot? Incase you need to bring it to the store for repairs.
Ok i have setcpu installed and to the MAX. And this phone STILL LAGS sometimes. Like when i try texting. It lags and half the letters dont pop up. And ive tried cleaning the caches and crap and it still lags.
And also is any cyanogen mod operable on this phone? I wanna do ANYTHING I can to speed it up
And i have also tried many task killers. Nothing will stop this phone from lagging unless its a memory issue or the screen is glitchy. Im a noob at this so any help would be greatful. I like typing fast and this is just terible
SOMEONE PLEASE THERE HAS TO BE A WAY TO FIX THIS DAMN LAG WITHOUT FLASHING ROMS OR ANYTHING. phone rooted btw.
heres a good walk through on rooting x2's BIG thx to XDA!
Originally Posted by DarkFalconX
This method works! There are only 2 differences in the commands (indicated in red):
Obtain the necessary files from the Atrix 2.3.6 link above
Extract the ADB-Fastboot package and root image to your C:\ Drive under a new folder titled ?root?
Put your device into Fastboot mode: ? Turn off your device. ? Hold down the power button and downward volume button until you see ?Fastboot? on your screen ? Push the upward volume button
Connect your phone via USB cable. Allow Windows to install the new hardware if this is the first time you have used Fastboot mode.
Open your command prompt (Start >> run ?cmd? >> enter)
Type the following commands
cd C:/root
fastboot flash preinstall root.img
fastboot reboot
Enable USB debugging (Settings >> Applications >> Debugging)
adb shell
/preinstall/su
Allow Superuser access on the phone when prompted
mount -o rw,remount -t ext3 /dev/block/mmcblk0p12 /system
cp /preinstall/su /system/bin/su
chmod 6755 /system/bin/su
PATH=/system/bin:$PATH pm install /preinstall/Superuser.apk
Congratulations! You are rooted!
This worked me also but I had to download superuser from the market first then follow the steps, and finally rooted
I have been trying to root my stupid x2 for 6 months. I can not get past the adb shell command. I continue to get the $ and when I type the su command it still returns a permission denied response. I would be most grateful if there is someone who can help me resolve this issue.
Whats the other method? I cant get past the fastboot flash preinstall root.img part!!!! so frustrating
What did you do? Im trying to do it as we speak and Its not accepting my "fastboot flash preinstall root.img" Cmd!! I dont know how to get past that part.
dumpsterrentals89
