How To Root Stock Droid Charge FP5
Re: How To Root Stock Droid Charge EP4D
Eclipse looks cool, I think I will try that. If I follow the Odin process once more with Eclipse, will I still keep all my data?
no you will not keep your data and it is NEVER a good idea to try to keep it either when you flash anything, either via odin or CWM.
The best way to keep your data is via mybackup pro or TiBup, you have to be rooted to use that particular feature though.
long story short, ODIN will always wipe your phone completely, CWM gives you the option to not clear data but you are asking for issues if you don't
Also, once you have full root & recovery, there is no need to flash rom via ODIN. You can just flash through CWM recovery.
Download Titanium Backup from the market. Backup your apps.
Put the rom you want in the root of the sd card, boot into recovery, install zip, clear cache, clear dalvik cache(under advanced tab), wipe data(to prevent any conflicts, it is best to do this), & reboot.
Your phone will setup like a new phone. Reinstall Titanium Backup from the market & restore your apps & data.
Thank you! Do I need to download another kernel or will Eclipse flash just fine with the stock root I did?
It does not come with a kernel. It "will " work with the stock kernel, BUT,...it will perform much better with a custom kernel. I recommend imnuts PB&J kernel. It supports custom boot animations(the one included in Eclipse is SICK), overclocking & generally smooths everything out. You flash it before you install the rom.
Again, it is recommended to use a custom kernel with custom roms. many are made to enhance each other. Imnuts PB&J is the most current & up to date.
Hey guys i got to step 23 just fine but on step 24 its not giving me the option down load. do you guy's know what i might of done wrong? any help would be great.
Did you create the folder yourself? Did you put it in the root of the sd card? It should be there.
Going to root this phone for a friend tonight and will post my results after.
Is this installing a custom CWM boot loader or recovery? And if it is (or even if not), can I install OTA's after root? :confused:
Basically, I want to make sure once I root this phone (no custom roms yet) that I give my firend the correct info as far as what to do if prompted with an OTA....
I have done root and install roms on my LG Optimus and Iconia so I am familiar with the process...
Thanks!
Edit: Root worked perfect. Big thanks to OP and TRParky for the excellent instructions. Would like advice on above question about OTA's! Thanks!!!!!
I made the mistake of creating the folder and forgetting to put on the sd card. my phone now is root it. thanks for the reply.
I can't seem to boot into CWM recovery mode, everytime I hold down volume up+Home + power it goes to the Android system recovery instead. Any ideas?
You have to reflash cwm the stock kernel overwrites cwm on boot
Sent from my SCH-I510 using Tapatalk
You guys are seriously helpful, you can't get any of this in any iPhone community. Thanks.
Okay so I finally reflashed CWM, I installed Eclipse v1.4 but I am still averaging close to 283 MB of RAM, should I be concerned if I am on this ROM?
that seems about right. I am at 284 currently.
I tried to install the CWM with odin and it failed. Now my phone won't start at all! HELP PLEASE!!
I had that when I first started you need to make sure that after your in download mode put the battery back in before flashing cwm
And it is recommended to use a rear usb port. I guess it provides more power. I have had it only fail once using a front panel usb. Never using rear.
17. Hold down volume up and home (button on bottom of phone that has an up arrow) and the power button
LOL Its a picture of a house, not an arrow, hence why its called the "Home" button.
Good info though. Thanks for posting it.:D
Does anyone have these files? Including Superuser file. It seems to be gone from Tom's website. He's converted to the Galaxy Nexus.
I've got Odin and CWM (hopefully a correct version that will work on the Charge.
looking for Superuser-3.0.7-efgh-signed.zip
Thanks in advance for pointing them out to me.
I don't have the link handy I'm not at my laptop...but if you head over to XDA charge forum, you should find everything you need. They are still pretty active there. I'll try to find the links to what you need in a little while.
Edit...here is the info as promised.
This thread has a version of the latest official FP1 ROM for the Charge...there are a couple versions, they are already rooted. There is tons of info that should answer any questions you have. That's one way to go.
http://forum.xda-developers.com/showthread.php?t=1560117
Or, here is a link to a page with the superuser zip file...
http://androidsu.com/superuser/
Sent from my SCH-I510 using Tapatalk 2
Reactions: RazzMaTazz
Maikai.Guy, were you able to find what you needed? Wasn't sure if you saw my post above with links to the files you requested.
Typed this up for a friend I thought it would be nice to share with any new droid charge owners looking for a guide to how to root EP4D.
Major Credit goes to:
trparky
I learned how to do this from his website:
Tom's Android Knowledge Base -- Offline
Root Stock Droid Charge EP4D:
First download this tool:
http://www.toms-world.org/android/download/ftp/MD5+It%21.exe
It will be used to run an md5 check on the files before they are flashed to your phone.
Next download this:
http://www.toms-world.org/android/download/ftp/ODIN3+v.1.82.exe
MD5: 3D8E8240F2A4F66E63A6622F65C7C909
This is Odin the *Windows* program used to interact with your phone.
Next download this:
http://imnuts.net/rCzxsR
MD5: 9C41377FDCDB341310BC8C25D0794D6D
This is CWM your main interface that will be used when loading roms, etc
<<<<the below line fails>>>>>looks like a fake 404 error
Finally download this:
http://www.toms-world.org/android/download/ftp/Superuser-3.0.7-efgh-signed.zip
MD5: A5D14DC42323A61CAF71549A885AF8C3
This is the file that you flash to root your phone.
Run MD5 Tool to make sure all the MD5's match the previous MD5 checksum!
1. Open the MD5it program
2. Drag the file into the file box and select MD5it!
3. Verify that the MD5 created matches the ones above (if they don't re-download)
4. Repeat for all files
Now you have all the files downloaded to root your phone. The steps to root stock droid charge are as follows:
Copy files to SD card
1. On the home screen select settings
2. Select USB setting and turn on USB debugging
3. Plug in your phone to your computer (give it a min to install drivers)
4. Pull down your top bar and select "Connect storage to PC" button
5. Create a new folder called Downloads
6. Drag the Superuser-3.0.7-efgh-signed.zip file into the Downloads folder that you just created
7. Hit the "Disconnect from storage PC" button on your phone
CWM
8. Turn off your phone
9. Once the phone is completely off take out the battery
10. Open Odin then while holding the volume button down plug your phone into the computer
11. When you get the Yellow triangle with android in it your in download mode, plug battery back in.
12. On the left under option uncheck Auto Reboot (you and leave F. Reset Time checked)
13. Once Odin picks up your phone (a yellow com box will show up) click on PDA and browse to the CWM file and select it
14. Click start (it should be a quick flash)
15. Once the flash says successful take out battery and unplug phone
Superuser
16. Put your battery back in the phone
18. Once you see the Samsung logo release the power button but continue to hold down the volume up and home button down
19. Once your phone has booted into CWM(there will be a banana at the bottom of the screen) arrow down with the volume button and select mounts and storage with the power button
20. Arrow down to the option that says mount system and use the power button to select it
21. Arrow down and select go back
22. Arrow down and select install zip from sdcard
23. Select choose zip from sdcard
24. Arrow down and select Downloads
25. Select the file that says Superuser-3.0.7-efgh-signed.zip
26. Arrow down and select Yes - Install Superuser-3.0.7-efgh-signed.zip
27. Select Go Back
28. Select Go Back
29. Select reboot system now
Let the phone boot up go the market and install root check it should say you?re rooted. Then your all done your phone has root that wasn't so hard was it:)
If you still are unsure or run into any problems feel free to send me a pm I would be happy to help you through the process via skype.
davidlmcshane
