How to set network mode in Korean Samsung note 2 - Model no. SHV-E250L ?
  • Start date Start date
A
AC Question
I am unable to locate network mode option in mobile network settings in my Samsung note 2. Can anyone please tell how to set my network settings, so that I m able to use 3G on my phone.
Offhand, I am not sure. Have you contacted your carrier about what settings should be correct?
In a Samsung phone, *#*#4636#*#* should bring you to the Testing screen. Choose Device info, scroll down to the dropdown and you can change the network type.
dial 319712358 then it will ask password type 0821 then network setting then network operator then choose. ok!
thnx bro for tell us to select network setting bur i also one more help i m using galaxy note 2 shv e250l (korian Model) here is show 2 language on my mobile keypad ( english, korian) i need remove korian language on my mobile keypad . please tell us how?
please reply me i m wating
thanks
my note 2 only support 2G although it can support 4G, how can i resolve this
"jhanin24;4997295 dial 319712358 then it will ask password type 0821 then network setting then network operator then choose. ok!"
this did not work for me
Its still not working dialing that number and setting on automatic mode,what i do now??? I m in pakistan having trouble wd my 3G activation although em in perfrct 3g coverage but still my handset is disabling me to use it... how cann i solve it plz somebody help me outttt
My samsung note 2 has a u+ lte but i dont know how to activate it cause it is in korean language, it is already in 3G but it has very slow data connection and a weak signal of 3G does my other phone perform, it always show G than 3G, how can i resolve this matter, badly need help,
what should i change in the settings?
to improve my 3G connection or 4G, hope you will answer my question i'm hoping thanks,
i dial *#*#4636#*#* ,
and it display the ff.
testing
device information
battery information
usage statistics
wifi information
what should i change to make my internet connection better, it really depressed me,
I am having the same problem. Can anybody help how to set 3G network in SHV E250L?
Thanks in advance
Keja
am unable to locate network mode option in mobile network settings in my Samsung note 2. Can anyone please tell how to set my network settings, so that I m able to use 3G on my phone. Plzz anybody say mi hoelw change network mode plzzz request for evryone olzzz
Rolon1924
