how to tell what exactly is using your battery
lazymac
104
3
Settings > About phone > Battery > Battery use. Mine shows 86% of total usage is caused by the screen. So turning it down helps.
Reactions: tepalma
On the home screen hit menu. Settings. Scroll down to about phone they you should see battery and in there click on what is using battery.
edit***I guess I didn't read your post. I thought you were asking. Haha
Screen is definitely the biggest drain. Odd, on my Inc it was only 7-10%.
Now it's 40-80% depending on usage. I know the screen is bigger but not THAT much.
it doesn't make sense that the display is using that much power, I have an app where I set the screen brightness to 0 and it still uses more than 60%
Anyone have suggestions as to how to reduce the amount percentage wise of battery use coming from the display? I have my brightness to about half but is there another suggestion?
Also, do live wallpapers use up more of your battery? I don't have one equipped but I thought about it but want to make sure it won't affect my battery...
I think it's kind of strange... I've been using my phone quite a lot (screen turned on & surfing websites and such) with wifi on... made 2 phone calls (1 was about 15 minutes long, the other was maybe 5 minutes)
Display: 45%
Voice Calls: 35%
I find the tremendous drain from my voice calls as curious to say the least. That said, I'm getting good battery life overall.
Mine do to , I thought that was bad *sighs* coming from iphone4 so the higher the number the better?
Display: 45%
Voice Calls: 35%
Voice has always killed the battery faster on any phone I used.
yes live wallpapers use more juice, they are cool but I never use them unless I want to show off a little
bantuanfintech
