How To Unbrick LGLS840 Back too LS840ZVC Firmware and fix OTA update Android 4.0.4 when released
Status
Not open for further replies.
The application failed to load because its side by side configuration is incorrect. Anybody know how to fix this?
Worked for me! After rooting the phone and doing a factory reset to sell the phone it would get stuck on start up screen due Sprint ID force closing. Hadn't used the phone in a few months now since i messed it up. Thank you for helping me recover the phone from paper weight status!
All I have to say is THANK YOU THANK YOU THANK YOU!!!! I had been trying to unbrick this thing for 3 entire days- doing almost nothing else- with no success. I actually had tried this one yesterday but couldn't figure out how to get the flash tool to actually start. Then I scrolled down and saw that someone else had the same issue and you helped them out now my PHONE IS BACK! YAAAAAAAAAAAY
I'm having a hard time changing the com port to 41. I found the USB serial port but I can't find the advanced tab to change it.
Edit: I didn't have the USB driver installed.
I just wanted to check out your prior kernel work to see how you can be integral to viper kernels. Nothing more. Also Check your Inbox, You misunderstood, I think that your a great guy, and your Write up was great. Please Restore your posts bro. I'm going to as well mine is re written, Actually found out when/why yours is more useful, and , more simple, except for the downgrade thing which i thought was a bigger deal than it is, but i hop on wifi and upgrade back to zvd instantly, ...(i am having Superuser Binary issues though, after downgrading/upgrading).
I also made it clear I have Official LS840ZVD as well. the reason why I put just LS840ZVC in restore method was too show that OTA would accept any update firmware that were push too the device
Re: How To Unbrick LGLS840 Back too LS840ZVC Firmware and fix OTA update Android 4.0.4
Well I sure hope someone has a copy saved somewhere because now since you two were acting like children we have no method posted on unbricking the phone.....thanks
Sent from my LG-LS840 using Tapatalk 2
So we are all clear. Nobody on this forum acting like a child. It was pulled personal reason. So please before you assume things please contact me directly If you any questions in regards too my reasons and please have respect I did it for personal reason. N0ve is redoing his unbrick method and updated his directions how too unbrick.
Let's see....there are several posts of "123" by n0ve, done mostly after people expressed their dislike of his method. Big deal....can't please everyone all the time, no point in pulling it...leave it up and say "i'm working on a rewrite" and then there is the bickering back and forth between you and n0ve over how your method downgrades before upgrading and now mysteriously someone asks you to pull yours down and you comply. I'm sure you have good personal reasons, but it smells slightly fishy to me. Thankfully I checked and I have some notes on your method so I should be ok and I can work on testing and writing them up better to post so we have an unbrick method up. Frankly yours work for me where n0ves didn't. It wasn't n0ves fault, I just wasn't able to follow as easily as I was able to yours.
Status
theantithesis
