How to unbrick your soft bricked Evo 4G
If you can boot into recovery, flash any rom with root. If you are trying to go back stock, you cannot flash it from within a custom recovery. You have to rename the file to pc36img and flash from boot loader. If you are getting errors during install, which step is it oon when it does this? Make sure you are using the right one for the hboot you have.
DumpedDuce Approves This Message Via HTC Evo 4g
Hello i am in desperate need of help, I think my phone is "bricked" ( i Know i am misusing the term but i have scoured the internet to find no help) when i try to install that rom(PC36IMG.zip) and when i do cwm says that the file is bad,i have also done it where the hboot sits and loads it (blue bar on right) and it never asks to update, If it helps anywhen i looked at my pmc36img file on my computer it says its invalid, I am on
***unlocked***
supersonic evt3 ship s-on
hboot-2.18.0001
microp-041f
touch panel-atmel224_16ab
radio-2.15.00.12.19
dec 21 2011, 12:50:32
please i have gone withouth my phone for 4 days because i tried to root it, all i want now is to get it back to stock, Please help Me!!:(:(:(:(
- - - Updated - - -
***unlocked***
hboot-2.18.0001
microp-041f
radio-2.15.00.12.19
- - - Updated - - -
***unlocked***
hboot-2.18.0001
microp-041f
radio-2.15.00.12.19
- - - Updated - - -
***unlocked***
hboot-2.18.0001
microp-041f
radio-2.15.00.12.19
- - - Updated - - -
***unlocked***
hboot-2.18.0001
microp-041f
radio-2.15.00.12.19
***unlocked***
hboot-2.18.0001
microp-041f
radio-2.15.00.12.19
- - - Updated - - -
***unlocked***
hboot-2.18.0001
microp-041f
radio-2.15.00.12.19
- - - Updated - - -
***unlocked***
hboot-2.18.0001
microp-041f
radio-2.15.00.12.19
- - - Updated - - -
***unlocked***
hboot-2.18.0001
microp-041f
radio-2.15.00.12.19
- - - Updated - - -
***unlocked***
hboot-2.18.0001
microp-041f
radio-2.15.00.12.19
If your pc is saying invalid, it sounds like a bad download. Have you checked to see if the MD5 matches?
I was trying to use kings shooter or whatever its called (it came up as tn_shooter on my desktop) but at this point all i want to do is reinstall the original rom, i dont care about the root now, maybe later but now i just want stock...
That's a very old ROM and I don't think it's been supported/updated in a long time. You may want to choose a current rom.
websitedesig97
