hp plugin for wireless direct printing stopped working
Blissed
10
hi... i did not have any problems in a year using the hp plugin for wireless direct printing with my officejet 8630.
just recently, when i try to "print" a document i get an error message "this printer is not available".
but when i "send" the document via the same hp plugin, it prints.
i have uninstalled amd reinstalled the plugin. i have cleared the print spooler cache.
wasnt sure if it was a good idea to clear the data. but, is that even what's wrong with the ability to print?
any feedback would help.
Welcome to Android Central! Which phone? Did it recently get a system update?
thanks, i will look into this. should i clear the hp plugin app data? i only cleared the cache. if i do, does it ruin the app?
Do the cache partition wipe first, to see if that fixes things.
DENIS GERASIMOV
