HTC 10 SD card requirements?
  • Start date Start date
I just put in an older 32G PNY MicroSD card, nothing fancy. There is a message that the card is not supported in notifications, yet it shows in storage, the music plays, I can see all the files in the file manager. I think its not compatible for internal storage, but for external like music it seems ok so far.
I found the phone to be real laggy so I took the card out and it reacts way better. I was hitting and hitting and nothing happening. It still happens a bit but now its much better. I dont want to use as internal storage, just storage. Any one have similar experience or one that works?
The card worked just fine, music played, pictures showed. Just the phone was slow and non reactive. I took the card out and 75% of it went away. It looks to me like it does something with that card all the time and the cards slow response is killing everything else.
the thing is you need a high end micro sd card that has read and write speeds of at lest 80MB I just bought a Samsung pro Plus which has write speeds of 95MB/s and read of 90 MB/S so I should be fien for using it for internal. that is the thing you just need a very fast card.
OK here's a question. Adoptable storage is a new concept to me. If I use a card lets say class 10 64gb, that's within the realm of the avg consumer, and it's used as adoptable storage. In 2-3 years could we say back up the media files we want and then reformat the card for use as external storage or to be reused as an adoptable storage device?
So what is best and largest card for media storage? And the largest best as adoptive? I'm running out of space quick. Thanks.
I have a similar problem but in my case it just stop working and get a notification of unexpeced sd card removed and have to restart my device. I call htc and they told me it may be a defective device with a fabric problem so i have to send it back for repair but that i have to pay for the shippment!!!
So, I've had a ton of issues with the SD card unmounting itself of its own accord. I thought it was from an app (Delayed Lock) I installed, since it seemed to start after that, but I uninstalled it, and it was still doing it. Mostly whenever I plugged it in to charge it, tried to update any app on the Play Store, or tried to use any file exploring app, like ES Explorer. It would also just "forget" the SD card randomly, so any app on the card would say it was not installed, or inaccessible, and the phone would restart itself sometimes, after forgetting the card. After removing that app, it wouldn't restart itself, but was still just forgetting the memory card, saying I had no card installed. I had the SanDisk Ultra in there (Class 10/U 1), recommended for the HTC 10.
It did work fine initially, as adopted storage, but, once the issues began, they have been steady, at least ten times a day, and incredibly frustrating, since I could not access important apps without restarting the phone, or even having to physically remove and re-insert the card, sometimes. Other times, within a minute or less, it would "remember" the card, no restart was needed, and I'd see the apps return to the screen, although I'd have to then go and re-set my ringtones/notifications each time, since those were on the SD card and most times the settings did not return, even once the card re-mounted itself.
What really sucks about the adopted storage idea, in trying to fix this problem, is that the data ONLY is accessible, within the phone, so, even trying to access photos or music on my computer, the card on its own isn't even recognized and can't be accessed, unless still in the phone. I was able to move most of the apps back, save the photos and music while the card was still in the phone, but then I couldn't access the phone via USB on my computer, since it still was associating internal memory with the original card I had in there. Even another card didn't solve that. I had to put in the original card, and re-format it as portable storage, to "release" the internal memory of the phone. I had wanted to save the card, in case I needed to transfer anything else, but the only solution was reformatting it, and then I could access the phone again, but, by then, I lost what I lost, as I am slowly finding out now, noting apps that aren't working, games that had 200+ levels of play, now back at level 1, ringtones and notification tones missing, etc. Small annoyances, and not a big deal, but irritating nonetheless.
So, I now have a new U1 speed card in there, a PNY Ultra, temporarily, and have ordered a SanDisk U3. However, I will no longer use the adopted storage. The only reason I did was added security, since the SD card gets encrypted along with the phone, but apparently the SD card can be encrypted as portable storage as well, then decrypted if you ever wanted to access it, independent of being in the phone, so that seems a good way to go. I don't have anything on my phone of much security concern anyway, so I think, based on the hassles of the adopted storage, I won't bother using that set up again, and either use the local card encryption or not bother to encrypt it at all, and anything like financials or whatever, I will save to the phone, since it is encrypted already.
All in all, a bad experience with the adopted storage. Not sure if that means I got a defective phone (I'm on T Mobile, but bought it, unlocked, direct from HTC) or they just have not ironed out all the kinks in this adopted storage concept, but the glitches are not worth the frustration, since it really doesn't gain much, plus shortens the life of the SD card, which you then run the risk of not being able to even access, if it starts going bad on you.
I'll see how the phone works just using portable storage, and hopefully it will work well -- this is my first frustration with an HTC phone, coming from the original MyTouch Slide, to the M7, the M8, skipping the bad sequels and waiting and waiting for this one, so I hope it settles in and works well. I hate having to replace a phone and start from scratch. Other than that, however, this HTC 10 is the best tech device I've ever owned -- the sound quality blew my mind, lol, I've never had any device be able to produce such high quality, plus the camera, video quality, screen quality, etc., so, yes, I hope this solves it, since I really want to be happy with this new HTC gem.
I had the same problem, after I got the phone I called HTC and asked them which card. They told me it had to be and XCHC class 10, so I ordered a 128gb and installed it and tried to format it for internal storage and the phone told me the card was too slow and could not be used for internal storage. So I called HTC again and got another rep and asked the same question and was told to get the Samsung MicroSD Pro XCHC 64gb, so I got one of those and same thing card too slow to use as internal storage. I took it out and set the 128gb up as external sd and loaded my music on and set the camera up to save to the sd card.
I had the same issue with my Samsung pro. I formated it as external then tried internal again and it was fine.
aktivasipinbnimobile
