HTC EVO 3D: Issues and Problems...let's talk about them here!
Re: EVO3D Issues and Problems...let's talk about them here!
I too have received the "upgrade" which has basically rendered my device useless. Well technically usable, just frustratingly slow. The screen is very unresponsive to touch. More so now than when I installed the upgrade a month ago. Like others it gets hot and drains the battery fast if used other than just a phone.
My biggest frustration is not being able to share a picture directly from the web to messages, facebook, etc. Now when I long press I only have the option to save or set as wallpaper. This apparently is not isolated to the E3D as the Galaxy S2 and S3 running on ics do not have the capability to do this either. It also affects all of the ICS devices I have come across. I downloaded several aftermarket browsers, only one was able to do this, however it was storing a copy of the image in a folder on my sim card.
Quadrant score, after the update my phone dropped from an average of 2800 to a 2100. This is very concerning to me.
I would like to go back to Gingerbread so I could use my phone like I did before. Although the Sprint store is telling me that is not a possibility.
To me it seems that this "Upgrade" is Sprint's way of accelerating the process of forced obsolescence. They roll out the update and make the devices barely functional. The phone still technically works so a replacement is out of the question. You are only left with buying a new phone which will at some point be ........updated.
This is why I will most likely not buy the LG Optimus G when it comes out. Had it hit the shelves with Jellybean Installed I might consider it. However I have been bit by the Upgrade twice now. With the E3D and my first Evo which after its firmware update spun into a series of constant reboots at random times. Most frustrating when using the GPS in rush hour traffic and you have no idea where you are going.
I understand the need to advance technology. But coming out with so many versions leads to more reverse engineering to make the versions compatible with older hardware. I would prefer to get a phone where the OS was specifically designed to work with that platform. It's possible that I may actually look at apple because of this.
Also this may be the reason I finally walk from Sprint. I am trying to hold out for LTE. If the LTE in the Tampa area activates but I cant get signal at my house, it's over. I will probably get the unlocked Nexus4 and move to Straight Talk.
That really sucks that had happened to you. I never used my phone with the stock rom, but from past experiences with other devices I can understand where you are coming from. I used rooted gingerbread, and ics with zero issues besides bloat, and now I'm running 4.1.2 cyanogenmod jellybean. It's a complete different world than the other roms I've used. I would recommend maybe rooting your device and hopefully the issues you are dealing with would subside.
Sent from my PG86100 using Tapatalk 2
Had my Evo since day 1 and have never had any problems, however after the last update I'm having an annoying problem. When my earbuds are plugged in I can hear any notifications/ringtones thru the earbuds as well as through the phone speaker so I can hear it and so can everyone else. The only way to stop this from happening is to turn my phone on vibrate or silent which is annoying b/c the vibrate function on this phone isn't that strong to where I can hear it or even feel it in my pocket while at work. Anyone else run into this issue since the last system update?
That's completely normal.
So here's the situation:
My Virgin Mobile HTC EVO 3D on ICS is having touch screen issues...but only in games. In games such as Minecraft: PE, Modern Combat 4, Modern Combat 3, COD:BOZ, N64oid, and similar games which use an on-screen joystick, it isn't working. I can place my finger on the joystick (or where it's supposed to be) and try and touch and drag, but it either doesn't respond or responds for half a second then acts as if my thumb isn't even there. It's really driving me insane. I'm not able to play any of these expensive apps anymore. My old EVO 3D recently killed itself due to an unknown issue, so VM sent me the phone I have now literally the day after Christmas. I had this same issue with my last EVO 3D. It's gotten to the point where I'm considering purchasing a PowerA MOGA controller, just so I can play these apps. Has anyone else had this problem? If you have a fix, PLEASE speak up!
Thanks!
Hello guys,
STILL NO SOLUTION
I have a huge problem with my HTC EVO 3D. In the Frequent feature in groups a lot of contacts that appear has nothing to do with frequency of inbound or outbound call. For instance from 18 registered contacts as frequent at least half of them shouldn't be even there. Whereas other contacts that i use on daily or every two day basis do not appear at all!!! This is really ridiculous since i cross check it with my phone service provider.
I bought the phone last February (2012) and i synced my contacts to my NOKIA 72 that's all...
Does anyone knows at least what factors (example number of calls/message/mails/twits/old records/call history transferred from previous devices) that affect the registration process????
Any ideas why this is happening. Please let me know if you have a pretty good idea about the subject or has happened to you to.
Hello,please help me .... I have a evo 3d i flashed to boost ...Everything was working as it should.
I rooted the phone s on using htc dev which was a breeze.
Well i have been thinking about s off so i did the j bear s off wire trick after a few trys i did get it and am s off.
After i cheered a little bit lol i checked my apps and turned off the wifi and the apps opened no problem.
Next i tried my calls and i got a error message saing my phone is not activated which it was ...
Ok so i went through the process i use to flash phones as i noticed my meid had changed.
Everything went fine...Until i did the handsfree and it failed...
I just need someone to help me get my phone working the way it was.
I'm not asking for help with flashing a phone at all!
I would just like to know how to remedy this issue.
I have a 3g icon that flashes up still and than the screen keeps going back to handsfree activation and failing.
I was rooted stock s on prior to this .Also now when i try to use my donor phone it fails handsfree also ????
Totally confused now !!! Please help
im stuck and cant boot a rom its in an infinite boot loop and i do not have a back up or restore point however i can open up recovery teamwin but......didnt make a back up i have tried 20 zips and no luck still infinite bootloop..........................................help plz
What rom did you flash and are you s-on or s-off ?
hi, i had the exact same problem with my contacts. i would add someone and they wouldnt be in my phone contacts and i would have to sync google to see them. it was very confusing. This morning i figured it out. when you are saving a contact at the top of the contact information page is a drop down menu, choose save to phone instead of saving to google +. It worked!!!
My htc 3d keyboard stopped working and people were telling me to reboot my phone...if you are having this problem DONT REBOOT People said that doesnt work...this is what you can do...I had to figure this out for myself
you dont need to reboot your phone at all...sign in to google(on your computer) since your keyboard no longer works...go to the google play store....type in keyboard for android...choose which keyboard you want click install....they are going to ask you where you want to send it to...make sure you are signed in so the phone you are using now will automatically be an option to choose where you want to send it to...so click on your android phone name...then and there it will automatically install to your android phone...your new keyboard will start to work...no new phone no reboot just new keyboard....
earlier today I got a notification for a system update which I'm assuming was for 4.2, so I downloaded it and it started to reboot to come back on, then wouldn't go past the htc screen at the initial boot until eventually it did nothing at all. I tried plugging it into the charger and the red charging light blinks and will go dim before it comes back on. After a couple hours on the charger, still nothing and then it went to the htc screen like it was going to boot, then went black again. I've tried pressing volume down and power to get to the boot menu, I've removed the battery and let it sit out for a few minutes and pressed the power button with the battery out to drain excess charge, and it's still doing the same thing. I'm expecting a call from my sergeant tomorrow and this is my only means of communication. I need help asap..
My HTC EVO 3D is so f-uucked up right now. Its actually restarting by itself even when its on full battery then when it restarts it comes back with 20% battery or sometimes drops a lot..why is this happening?
Im also experiencing - EXCLAMATION POINT on my battery instead of the actual battery reading...why is this happening? has anyone else experienced this before?
Is it just me or are the viewing angles when watching 3D content completely and utterly terrible ?
My HTC EVO 3D is ruined. Its actually restarting by itself even when its on full battery then when it restarts it comes back with 20% battery or sometimes drops a lot..why is this happening?
The exclamation on the battery I have experienced this a few times but not the random shut downs. I am almost certain that you need a new battery. To test this, leave the phone pluged into the charger permanently and see if it switches itself off. If it dose not then its definitely your battery. Also rub your fingers on the battery to see if it is swollen or look very carefully. As for the battey reading try battery notifier big text from Google play.
Let me know how it goes. :)
I am new here so bear with me.
I've been using EVO 3D for about a year now. I love it but I just have few problems that I have been wanting to fix. It will be nice if someone can advise how to fix the problem or lead me to a thread about how to fix the problem. Thanks in advance. (FYI: my phone is a Japanese CDMA by au KDDI and it is not rooted)
1) Notification LED does not flash longer than 5 mins. I'm sure a lot of people had this problem but I never saw an answer to this.
2) My phone does not push notification sometimes such as Emails and Texts when I am using only Wifi. (Maybe it is the Wifi problem)
"Push Notification Fixer" seemed like a really nice program but I do not have the phone rooted.
3) My Wifi stops the connection after the phone goes to sleep. (I made Wifi always be on under the settings)
4) I am not sure if some of the programs are running in the background or not. (The programs I want the phone to always be running in the background: Google Talk, Gmail, and Textplus)
Please help me out how to fix these problems. If I have to, I try to root the phone except I'm not sure I can root the phone same way as Sprint EVO 3D. Like I said, my phone is Japanese so I have a feeling it makes things a lot more complicated.
For a while now i`ve been having some sort of problem with my battery. I believe my charging socket somehow got bigger than it should be, cause i can`t charge it from the original charger (the usb keeps wiggling and the phone keeps jumping between charging and not charging like crazy). Anyways, i noticed something wrong with my battery icon at occasions, and this seems to happen randomly, along with a quick green - red LED flash.
This is what i`m talking about. Any help is much appreciated :D
Regards
For a while now i`ve been having some sort of problem with my battery. I believe my charging socket somehow got bigger than it should be, cause i can`t charge it from the original charger (the usb keeps wiggling and the phone keeps jumping between charging and not charging like crazy). Anyways, i noticed something wrong with my battery icon at occasions, and this seems to happen randomly, along with a quick green - red LED flash.http://i43.tinypic.com/5xor68.jpg This is what i`m talking about. Any help is much appreciated :D
Regards
Thats a bad battery, Time for a new one. Does it seem to be buldging at all, should be good and flat on either side
How do I disable background data and adjust screen brightness/time out when battery low ?
I lost these settings/options when I did an OTA update. (currently running sense 3.6 and ics)
OS services are wasting my data plan (about half a gig in about half a month)I've contacted HTC about this but no success. it's strange. when I had gingerbread and sense 3.0 adjusting these settings was easy but as soon as I updated the settings just vanished in thin air. so how do I disable background data ? And what is wl0.1 ? it's consuming a lot of my data aswell (almost 100MB)
hardva
