HTC EVO 3D Kickstand Cover?
Seidio is now shipping the SURFACE (with kickstand) case for the HTC EVO 3D.
Thank you for your patience.
Seidio
Picked up the platinum kickstand case at best buy. Happy that it doesn't add much bulk since I carry it in my pocket and the fit is perfect. The case comes out just past the camera lens on the back which is nice but at the hinge for the kickstand there is a stop that keeps it from being totally flat. The finish has a soft rubber feel to it. It also doesn't impair access to any buttons or or ports.
I would have liked to be able to charge the phone while on the kickstand but not everything auto rotates with the volume buttons on the bottom. So it makes sense that it opens the way it does. Some holsters can be used as rotating stands but a holster is not my thing. Overall I'm happy with the case.
I bought this case as well. It's perfect IMO. It looks like there isn't even a case on my phone. It easily slides in and out of my pocket.:)
The seidio Surface case with kickstand is ok. It has a good feel but the kickstand isn't up to the EVO 4G kickstand quality and you will need a fingernail to open the kickstand. It's held tightly in the locked position. DO NOT get the Seidio desktop cradle IF you're looking for a desktop cradle solution to go with your case. Too much wiggle room and the phone sits on the usb port and leans to the right several degrees. It's a poor fit and poorly designed to work with that case.
Baadshah
