HTC evo 4g Will not power up
Frank Fouch
4
I have an HTC evo 4g 3d, I purchased it used,worked great but was only able to use for 8 hours, then acted like battery died, bought new battery and still will not charge or power up, the charge light comes on for about 30 seconds then goes off, every once in a while it will start flashing
Welcome to Android Central! I moved this from the EVO 4G LTE forum to the EVO 3D forum, just so that it's in the most appropriate forum.
Does the new battery charge up if you keep the phone plugged into wall outlet for at least 6 hours, undisturbed?
Have you already tried a different charging cable/plug? If that doesn't work, then it's probably a hardware problem, which could be the charging port, the Power button, or the motherboard -- you'd have to take it to a repair shop to find out.
cinemacritic
