Huawei P20 Pro (CLT-L09) battery drain
  • Start date Start date
I was told by huawei to wait for a couple of days till NPU adapts to my battery usage. Let's see. Now my SOT is 2 hours and 55%.
Unfortunately in my country you have to deal with a service centre, no way to change at the place of purchase.
Goto Settings>Battery>Consumption and it will show you the hardware and software that is drawing on your battery.
Then go into Battery Optimization and see if any of the highest battery drainer are turned off.
Just checking my SOT: 2h13m from 100% to 60%. But my hardware has consumed 39% with software the remaining 61% of the battery consumption.
Looks like we are having a similar performance then. I've see guys boasting 7 or 8hr SOT providing screens and still having around 30%, but most likely it really depends
like I said though must of the power consumption was reported as software not hardware. Not sure SOT is as goos as an indicator as was in the past.
In my case software also takes the most percentage.
Right, so I don't think posting and using SOT benchmarks are as significant for battery use anymore.
But back to the OP seems like we are in the same ballpark for battery consumption.
Crusher
