Huawei y6 ii cam l03 Slow wifi when tuning on bluetooth
  • Thread starter Android Central Question
  • Start date
A
Hi All.
I have the following situation on my Huawei CAM L03 Y6 II.
WiFi gets very slow when turning on Bluetooth (ie. Page loading in browser takes for ever) .
A soon as I turn Bluetooth off, browsing starts working fine again (pages load fast).
This happens on my Huawei CAM L03 Y6 II Android 6.0.
Any ideas, suggestions?
Thanks!
Juan
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
I'm guessing that you're not that close to the router, and you have a weak 2,.4GHz wifi signal. Since Bluetooth is also on 2.4GHz, it's interfering with your wifi signal. (If you're close to the router, the wifi antenna in the phone may have gotten disconnected, or the wifi receiver may have gone bad.) There's not much you can do (unless there's a problem with the phone and you get it fixed) except to use 5GHz wifi if you can, or to turn Bluetooth off when you're using wifi if you can't. You can't change where they operate.
ukfred
