Hub issue help
Gelzz
5
I have this error on my hub when I'm deleting a text either on hub or messenger app on android
It happens if I delete the text message on hub and I'll go on the message app and try to delete it there and I get the same error message and vice-versa if I do the same on message app and I get the error on hub.
Hope anyone can help
Thanks
You can see the hub to delete on server and device or just device. If you want hub to handle it all, disable sync from Gmail and the hub will handle it. Make sure you get you messages. I have the same set up and it's working well.
opegamani
