I am having few problems with my GS2
Kaitlin Allen
Okay so i have had this phone since the end of jan. It replaced my old one which wouldn't stop hanging up on people or resetting itself
.1. This phone the first week started hanging up on people and is now doing it more often and i noticed while im on the phone before it hangs up on people it makes this weird clicking sound and cuts them off for like a second but only i can hear it , it does that a couple times then hangs up with no warning.
2. The past few days my Wi-fi and 4G will randomly turn themselves on i dont know why.
3. I plugged my phone into my laptop to sync my new music onto the laptop so ill always have it incase it doesnt save on the memory card because its done that before. but when i went to sync it none of my recently downloaded songs are showing up on Phone or SD card and i remember setting it to immediately save to SD card so i don't know whats wrong with it.
4. sometimes the phone will freeze or just reset itself with no warning either.
HELP?:'(
Unfortunately thats how the phone is. I have the gs3 and it does the same. I should of stood with my iphone.. I bought my husband the gs2 for Christmas and its nothing but problems it freezes he has to remove the battery to put it back on, the phone gets really hot, hangs up calls. Ive heard a lot of people complain so im guessing thats how to phone is...
Sent from my SAMSUNG-SGH-I747 using Android Central Forums
Did you buy it new? If so, get it replaced under warranty. If not, try a factory reset.
I use the SGS2 for month now and have not encountered this problems. Everything is fluid and responsive. I installed the nova launcher app, because the touchwiz feels like crap. but when you are not happy, you can always install cyanogenmo 10. should work perfectly on the samsung galaxy s2.
Do you have the same apps installed as you did with the first GS2? Since you have very similar issues it could be related to a bad app.
Sent from my GT-P7510 using Tapatalk 2
Please somebody help...my phone is stuck on logo and when I go on my clockworkmod recovery its says error in cache/recovery/log n it also says no space left on device which there is space...everytine I try to factory reset or try to do anything on my recovery it justfreezes/stops....PLEASE SOMEBODY HELP ME ON THUS????
Equatorial
