- May 26, 2016
- 9
- 0
- 0
Hello,
I tried to find a solution for my problem, yet it seems like nothing really helps. I cleared my cache some time ago, due to another problem I had with my Samsung Galaxy S6, and since then, it seems like my battery went crazy. I've tried to clean the cache, disable almost all of the running services like Google Services, OneDrive synchronises only when charging, location is off almost all the time unless I use GPS, Wi-Fi is on only when the phone is awake, disabling/uninstalling everything that I don't use, disabling most of the programs that ran with the startup, disabling all the automatic updates (unless charging), disabling almost all of the sync, except my emails, calibrating the battery twice... It seems like the solution lasts only one battery charge, and the next one, it takes unbelievable amounts of battery. Android System tends to get around 50% or more of all the battery, and I have no idea what else should I disable, in order to make that usage less. Two examples from yesterday and today:
Yesterday: Disconnected my phone before I went to sleep; slept from 1 am until 10am, which consumed around 30% just by standby. Used it a bit, started working from 2 pm until 9 pm, my phone was on Airplane mode almost all the time during these hours - when I went to work, I had around 40%, to find it with only 9% battery left when I finished. As you can see, I almost haven't used my phone at all, with Android System taking 49%, followed by Android OS with 27%
Links: http://i.imgur.com/Mdzayhy.png, http://i.imgur.com/ACCwM9H.png
Today: Charged my phone and disconnected it before I went to bed yesterday (went to bed around 1:30-2am, woke up at 10am), seeing that I have only 60% battery left, and I fell asleep with 95%. Unsurprisingly, Android System takes 68% this time; what surprised me was that it says it stayed awake for more than 8 hours, when in fact I wasn't using it, and didn't even receive a single notification/email/message while I was sleeping.
Links: http://i.imgur.com/dg6TK55.png, http://i.imgur.com/0CpHsQJ.png
Does anyone had this problem before, and is there a solution? I'm not a heavy user, I usually play a few games now and then, browse the internet and listen to the music when I'm driving, so nothing excessive... I don't want to do a factory reset, but it seems like something is really wrong with it - all improvements I try to make last only one battery charge; since I got this phone last September, I almost always have fully charged/discharged the battery (and by fully I mean putting it to charge with less or equal to 5% battery, almost never let it shut down itself), and I have all that drainage that I can't find a solution too.
Any help would be greatly appreciated!
