I can't use my Huawei Ascend ll.. Please Help!
I have discovered that every time I install the Facebook app, I have this problem. If you have the Facebook app, push and hold the search soft key at the bottom right. When it says to speak a command press the speak again. It will let you speak a search item. Doesn't matter what you say. When search comes up, search for play store and search Facebook. When you get to the download for the Facebook, if you have it on your device, it will give you the option to uninstall. Once the app is uninstalled, restart your device and it should be working fine. Don't download it again!
CathyAus
