i forgot my password/pin # for ColorNote and have tried every single password/pin#
  • Start date Start date
A
Android Central Question
I've tried every password/pin# I've ever used & no luck.
Keep trying, because passwords are not meant to be bypassed. If you can't remember it, then I'm afraid you're out of luck (I use Color Note too and don't recall seeing a forgot password option to reset it). In the future, I suggest using a password manager to help you keep track of them, especially those you don't use often.
Welcome to Android Central! You could also try contacting the ColorNote developers to see if they have some sort of backdoor method of unlocking the app (although that would pose some serious questions about the security of your data in that app).
Gasho
